Hey guys Aaron here again new to the sit this is my first 01 Volvo V70 24T love the car if i would have known transmission issues ahead of time would have back off from this car owned eight different Volvos never a transmission slip or flare like this one i changed my radiator out lost a little tranny fluid but checked it at normal operating temp seems to be at right level now car all of sudden seems to have slight transmission flare or slip when coming to stop or right at 2nd - 3rd gear ???? Only in stop and go traffic after a while get on highway all is fine shifts smooth through all gears come to to stop fine takes off fine only happens after a while stop and go what could it be ?? Ive been reading different forums answers to get transmission tcm reprogrammed or something like that dont know any advice appreciated
Thanks
Aaron. 2001 Volvo V70 24T
Sudden slight Shifting Flares 01 Volvo V70 24T
- Has thanked: 1613 times
- Been thanked: 4075 times
Aaron - please check out the sticky thread on 2001 transmission problems to get yourself started on the options here.
viewtopic.php?f=9&t=75828
Please break your sentences and paragraphs too, word salad is against Forum posting rules.
JRL
- Year and Model: Several
- Been thanked: 16 times
You need a new or rebuilt valvebody (at best)
You need to post mileage and any known service history
Thanks for some of the advice guys this Volvo my only set of wheels right now mileage is around 150k dont know when transmission fluid was last changed or filter owned car about two weeks been doing work on it since. Is the valve body pretty tough job to replace and if i do it my self does the transmission need reprogrammed? I want to know if the tcm needs reprogrammed before i tackle or have volvo shop tackle valve body job ?
user17600
- Year and Model: V70A, 04; XC70, 06
- Been thanked: 2 times
Before you replace anything, read up on how to check the fluid (right temperature, engine running, etc) and check it again. Your statement about this starting with the loss of a little fluid during the radiator swap is a flag.
When I changed the fluid in my '04, I had similar symptoms after changing the fluid, but when I fully warmed the fluid up and checked it again, I found it was a bit low. Added a few ounces at a time until it was near the top of the operating range, and the symptoms were gone.
If you don't have VIDA, you need to run it for a good 30 mins to get to the right temperature to check it.
JRL
To answer your question, if you install a V/B YES... new (updated) programming is required and actually should be done anyway, with or without a new V/B.
Start with checking the fluid first for a correct HOT fluid level and color.
Hot means at least 30 minutes of running, the cold level is irrelevant.
If black (but not burned) change the fluid ASAP, get all updated software downloaded and see what that does for you.
- 594 Views
- 509 Views
Last post by bbeels
- 31 Replies
- 6779 Views
- 1159 Views
Last post by packetfire
- 1788 Views
Last post by jonesg
