ok please help me out here....
my car 2000 s70 is making this stumbling sound...its not like all the time but especially when I'm slowing down and accelerate after I can here or feel this stumbling or cracking which I think is coming from the engine or something very close to it......pls give me some ideas........thanks
2000 s70 stumbling sound
- Year and Model: Many Volvos
- Been thanked: 75 times
Since I'm not sure where you are from and, as such, don't know how to tailor the question, is your Check Engine or Lambda light on?
If so, you need to have the codes checked and cleared, it can often pinpoint the problem.
If you have codes please post them. That will help us narrow down your problem quickly.
Other common items that result in your problem is spark plugs, spark plug wires, distributor cap, distributor rotor, fuel filter, vacuum leaks,
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
No codes but stumbling or "cracking" sound? The cracking is something that concerns me and I'd like to know more about this sound- what you mean exactly... If it happens as you let off the gas it could be the exhaust manifold that is loose from the rest of the exhaust and thus needs tightening, or in the worst case, it could be cracked....certainly seems to me that your problem might be related to some type of back pressure issue...especially if you have no codes. It would take getting under your car and looking (heat shield off) to see if your manifold/exhaust connection could be the problem.
when i'm applying breaks to stop sign /let say/ and accelerating after the engine just make this sound like skiping one gear or something like that.....it doesn't feel good
just now i'm dealing with the sparkling plugs and I will do fuel injector cleaning.....let see what happens
p.s. Lee you are the best.....thanks man
