NEW V8 Timing Cover Reseal Kit from FCP EURO
This topic is in the MVS Volvo Repair Database » V8 Timing Cover Leak Job Parts List
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Hey Mathews,
Anyone who has a Volvo V8 is usually a big fan of its performance, reliability, and feel. However, it's no secret that the timing cover on the Volvo V8 can leak over time and after recently having to perform this job on my own personal vehicle, a 2006 XC90 V8, I quickly realized that there are a ton of parts to replace to do the job correctly and that there really wasn't a good kit on the market for us enthusiasts. I created this kit which includes all of the gaskets, seals, and hoses needed in order to reseal or replace the timing cover on the Volvo V8's. Another reason as to why this cover needs to be replaced can be due to the serpentine belt idler or tensioner failure which, when fails, put a tremendous amount of pressure on the boss incorporated on the timing cover itself. When this happens, the boss will break off and require the cover replacement.
On the product page of the kit I've included links to a few more items that may be considered when replacing or resealing the cover such as:
Serpentine Belt Tensioner - https://www.fcpeuro.com/products/volvo- ... 0-31216199
Idler Pulley 2 needed - https://www.fcpeuro.com/products/volvo- ... 0-31216198
Spark Plug Set - https://www.fcpeuro.com/products/volvo- ... 0-30731383
Fuel Injector O-Ring Kit - 8 needed - https://www.fcpeuro.com/products/volvo- ... 0-30731386
Timing Cover - https://www.fcpeuro.com/products/volvo- ... 0-30720104
Timing Cover Bolt Kit - https://www.fcpeuro.com/products/volvo- ... -volvo-kit
I personally just bought my XC90 V8 with about 151k on it and it was in need of some TLC. I also wanted the set the car up for years of reliability.
With that said, I replaced a few other components such as:
Alternator - https://www.fcpeuro.com/products/volvo- ... v8-al0821x
Although not faulty it was saturated in oil. They're also known to over heat on these cars so I thought it was a good idea to replace it.
Power Steering Pump - https://www.fcpeuro.com/products/volvo- ... 0-36000748
This was leaking....and leaking pretty bad. What happens to these cars is that the fluid travels down and across the balance shaft cover and down along the block and down onto the transmission. It resembles a rear main seal leak but its actually coming from the power steering pump.
Water Pump - https://www.fcpeuro.com/products/volvo- ... 0-30731384
While not leaking, I noticed a small amount of coolant crust built up on the freeze plug of the pump. I thought it was a good idea to replace while I was in there.
Lastly, It not a bad idea to replace some filters and fluids:
Engine Coolant - https://www.fcpeuro.com/products/volvo- ... vo-9434699
Power Steering Fluid - https://www.fcpeuro.com/products/volvo- ... d-30741424
Maintenance Kit - https://www.fcpeuro.com/products/volvo- ... in-kit-kit
I went with the Pentosin kit. The Fuel filter on my car was original and I can't begin to describe the gunk that came out. In fact, as soon as I replaced it, it triggered a fuel pressure sensor code and I had to replace the sensor
Fuel Pressure Sensor: https://www.fcpeuro.com/products/volvo- ... 0261230110
The Air filter was in bad shape and the plugs were in desperate need of a replacement. While I had the valve covers off I figured it would be foolish not to replace. Also, just in case any gasket material fell into the pan while the timing cover was off, I performed an engine oil change as it needed one anyhow.
The job was not difficult however very tedious with lots of cleaning involved. I'm convinced this engine is good to go for at least another 100k miles (I hope).
I know there's an S80 V8 on here with over 300k, how many miles are on yours?
If you have any additional questions please feel free to reach out to me personally at [email protected] or check us out at FCPEuro.com
Always happy to help
Jason
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
Thanks for the info.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
FCPEURO
Post by FCPEURO »
Anytime!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Yes, good info for V8 owners. I'll put this in the Repair Database in the next few days.
Also -> Amazon link
