I just got this lovely beast (79 245 DL)that came with an old BOSS (remember these)head unit that did not work, and just filled the hole for the radio. I got a new head unit etc but I can't figure out the wiring at all. The car only has two speakers so figuring those wires is easy. The only thing that is left (besides the antenna) is one black wire an one white wire that both feed into the same connector.
I run the volt tester on each one and did not get power from either of them.
Continuity tester shows no breaks in either wire.
All the pillar fuses are fine.
Am I missing something? Is there another fuse somewhere I could be missing?
Is this just dreaded 70's Volvo wiring?
Any help is appreciated.
1979 Radio Replacement
waterman72
- Year and Model: 1979 245 DL
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
1980waterman72 wrote: ↑12 Apr 2017, 08:32(79 245 DL).... one black wire an one white wire that both feed into the same connector.
Check Fuse 1, both sides...key switched...black wire
There is a black wire from radio that goes back to power antenna...it may be a ground when radio turns on...MAY...a green wire feeds power antenna via fuse 8.
Off of radio, there maybe a gray wire for a ground...MAY
Volvo didn't show much back then
