Location of Coolant Temperature Sensor
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: Location of Coolant Temperature Sensor
Post by jblackburn »
Exactly the same - the bolts are actually easier to get to on a 1999.
Double check the part number before you order; I'm not sure if that's one of the differences between a 1999 and 1998. I think it's the same.
'98 S70 T5
2016 Chevy Cruze Premier
seth1991
Year and Model: V70, 1999
Post by seth1991 »
Thanks for the response! It sounds manageable now. Do you also happen to know if this the right part for the CTS? http://www.ipdusa.com/products/5728/113129-engine-coolant-temperature-sensor. Again, a 99 V70 non-turbo. It appears to be correct, according to ipd, but I wanted to verify. Thanks so much!
jblackburn
Well...yes. But that's aftermarket.
Everyone I've heard of that's used an aftermarket temp sensor had their car acting like crap afterwards. Volvo's are super picky about their sensors - so go OEM and don't have to replace it again in a short while.
http://www.ipdusa.com/products/5727/109 ... ure-sensor
'98 S70 T5
seth1991
Post by seth1991 »
Perfect... thank you so much! What a great resource. I appreciate it.
jenkinskg
Year and Model: 04 c70 hpt 98 s70 xc
Post by jenkinskg »
Could there be another temp sensor, I replace thermostat, came with new sensor.
Radiator fan not turning on, also did this for previous owner I believe.
Vida can turn on fan, but ecu cannot, any ideas?
2004 c70 2.3HPT, s60 2.5T
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
seth1991- yes, I believe so. Just don't get an aftermarket sensor. Make sure you get the right one. If in doubt about a local one, look on FCPEuro.com to make sure. I went through a ton with problems before I bought the right one!!
