I have a 04 2.5T AWD with 205k miles. I have had it for 50k. I live in Colorado but I'm a new immigrant. After three garage visits that revealed disastrous in spite of recommendations, I had started learning to do some maintenance myself
For quite a while it had been shaking when braking. It was obviously not the rotors ; after checking this great forum I learned it could come from the control arms bushing....which indeed were looking very bad. I had unfortunately let that aside by lack of budget for several months
Lately, it has started shaking much more (like if the wheels were a bit oval LOL) and without braking, when in straight line, above 45 or 50 mph. It has also been wearing out the FL tire like crazy. So i am pretty sure that 1. the alignment has gone banana (I live on top of a 15% steep gravel driveway and I drive 30% of the time on gravel road) and 2. the control arms are dead, and 3. I suspect quite a few other suspension parts are dead too.
I plan to replace now the control arms of course . I checked some instructions here and on Swedespeed and - whereas it is way more involved than what I have done so far, I think I am ready to go there. I will certainly need to do the tie rods (not sure of the vocabulary) BUT, considering the age and low resale value of the car, I'm not too keen into starting buying and replacing for several $100s of parts without being relatively confident it will solve the problem...
I suspected the bearing may be dead, but when trying to move the wheels with the car on stands, I can't feel any movement or hear any noise in the area of the bearing ; the noise (and the movement) comes from the suspension parts and from the steering rack. It moves also when push/pulling at 9 and 3 oclock, but not when doing 12/6 o'clock - which I read indicates indeed that it is rather the suspension parts rather than the bearings. That said, hubs are quite inexpensive and while pulling out everything to access the control arm maybe I should do them to be on the safe side?
If I could NOT have to do the struts - that would be great ($$$) . I know the car would be better with - but at this stage all I want is solve this shaking problem.
I noticed that the parts that connect to the steering rack move with some noise. Is it normal? Should I replace them too? (see video)
I noted that the CV boots look "young" for 200k - so did a sticker on one side on the axle - so I suspect some work has been done before I got the car.
I noticed also that the differential on the front axis...well it is very greasy ; when on P, spinning a front wheel will unsurprisingly spins the other one in the other direction...but this movement has a lot of play, and it is noisy, Is it normal ? (see end of the video) Could it partly explain the problem ? (I don;t think so as the shaking is there even without accelerating).
I tried moving the rear wheels - nothing there.
Last - I noted that one small silent block holding the engine at the bottom is "missing" - probably so dried out that it fell. The big one on top is cracked. Is it easy to change? (see photos)
Thanks for any advice. I'd be glad to pay a reliable person in Denver or nearby to help me out with the diagnostic
Photos:
Video
