I went to the JY today hoping to score a set of jewels from an 04 C70... Of course someone plucked its good eye out, and the other has a chip in the lens. So I contented myself with getting the master window switch, and went to search the yard for a steering wheel.
Found a V70R in the very back row. Black to match my T5, so I got the front bumper. the right side door latches the steering wheel and the aluminum trim. Also I grabbed the greens. I'm going back next week for the struts, 302s, turbo and rear bumper.
It's a 99 with heated leather quilt-pattern fronts and alacantara rear seats, tan. Three door panels are good (of course they need re-gluing of inner to outer and some of the clip holders.), the drivers speaker grille is destroyed, and the stitched insert is pulled out (I imagine it could be cleaned and glued back in to a different panel) It's the wrong color for my T5 and I have mechanical airbags, otherwise I'd be rockin' an R gut. The best part is the car is not on the yards Row 52 listing, so it's kind of a secret.
The prop shaft to the rear is still there, and the hood and RH front fender were damaged. The LF wheel is not there, but it has 3 good solars. Blue cluster still there.
PM me with serious requests. I'm no Robert, but I'll see what I can do!
Patrick
unadvertised V70R in PnP yard
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Current Volvos:
Paul8fiddy
- Year and Model: 1996 850 Turbo
How much would you get the exhaust manifold out for?
