First S40/ VVT timing belt service questions
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
drucken68
Year and Model: 95 850 GLT
Post by drucken68 »
Hello,
I have my first VVT unit ongoing now for a timing belt/water pump, vvt etc. I have done many other 5 and 6 cyl white block timing jobs without issue, The car I bought was making a nasty noise in the top end right after start up, but quieted nicely to a normal idle. The car is in pretty decent shape and it was a cheap project, well so far. I have purchased the VVT pulley ( intake is the only one with VVT on this model) Solenoid, all the timing belt parts etc. My question is that when I have watched some good tutorials on the VVT, the unit appears to have maybe 3 or so teeth of movement to the limit position, then it springs back. Neither the one I removed or the INA one I have purchased have more than 2mm or so of movement. I understand some units did not spring back and had to be moved manually, but is it normal to move so little? I was under the impression that they all had similar movement. I currently have the old parts disassembled with cam/crank locks in place as I figured I would try to confirm this before reinstalling. Thanks in advance!!!!!!
1994 960 160k
1995 850 GLT 200k +
1997 850R 122k
drucken68
Post by drucken68 »
I thought my model was posted..............its a 2006 S40 N/A with 135000 and timing looks to be original.
1994 960 160k
1995 850 GLT 200k +
1997 850R 122k
