I haven't changed a tire since I was in my 20s and yes, I/we used the awful jacks of the day that came in the car.
However if I had to do this again these days, I would figure out a different way.
I would NEVER use a scissor jack again!
I know enough now to know this is a real bad idea!!!
Instruments of Death P2 Volvo Jack
Are Volvo Jacks Dangerous?
JRL
- Year and Model: Several
- Been thanked: 16 times
- Has thanked: 312 times
- Been thanked: 818 times
Always good to be reminded of the very real dangers of working under a car.
So is everyone who keeps saying "floor jack only" or "jack stands only" actually carrying a floor jack and two jack stands in the car at all times, for the pesky flat tire situation? This thread is about what to do when you are on the road, what to have in the car to make that situation a little less dangerous. Doesn't seem like there are any good solutions, alas.
zombielinux
- Year and Model: 2007 XC70
- Has thanked: 1611 times
- Been thanked: 4075 times
You loosen the nuts/bolts
Spare is out of the trunk or hole, ready to go.
Block and jack, tire off , spare on. Get two nut finger tight asap. Elapsed time car is without wheel, 30 seconds or less
JRL
Call AAA
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Depends. Guessing the right height for the donut is easy. But if you're trying to get a full-size spare in there, you need to keep jacking and jacking and jacking. Which reminds me,I really should put one of spare scissor jacks in there...abscate wrote: 06 Jul 2017, 20:14 You loosen the nuts/bolts
Retired:
2015 Volvo S60, T5, 85K
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
"...I really should put one of spare scissor jacks in there..." Do whatever will work but make sure your scissor jack has a saddle which will work somewhere under the car.
If you rest the spare against the wheel being changed , you can lift it until the hub is above the spare hub. If you let. Your car communicate, it eliminates guess work!theWIFES_S70 wrote: 06 Jul 2017, 21:34Depends. Guessing the right height for the donut is easy. But if you're trying to get a full-size spare in there, you need to keep jacking and jacking and jacking. Which reminds me,I really should put one of spare scissor jacks in there...abscate wrote: 06 Jul 2017, 20:14 You loosen the nuts/bolts
- theWIFES_S70
And ruin my paint???abscate wrote: 08 Jul 2017, 02:18 If you rest the spare against the wheel being changed , you can lift it until the hub is above the spare hub. If you let. Your car communicate, it eliminates guess work!![]()
I chock wheels with those rubber chocks from Harbor Freight and stick a 50lb bag of sand behind one chock and a few cylinder blocks behind the other. Safety first!
Retired:
- 4053 Views
Last post by WagonLagan
- 1099 Views
Last post by hyllus
- 15 Replies
- 2368 Views
- 793 Views
Last post by wizechatmgr
- 1618 Views
