Instruments of Death P2 Volvo Jack
This topic is in the MVS Volvo Repair Database » Are Volvo Jacks Dangerous?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I'm carrying the HF speedjack and 1 jackstand in the car since my scissor jack seized.
Could be dangerous but anyone rolling a volvo deserves to get hit with a jack.
I used to have neat little folding chocks from pep boys, forgot they were behind the wheel and drove them.
They got flattened.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
abscate wrote: 25 Jun 2017, 09:14 Is it different than the P80?
I love the P80 jack but have never used my P2
The P80 jack is absolutely terrifying unless you are on an absolute 0* slope.
Since you often can't pick when you have a flat...look out. We all know P80 parking brakes have a tendency to...not work, so tiny foot, tiny shift as the car comes off the ground = very prone to falling over once the wheels come off the ground.
I went and got a Jeep jack with a nice big foot for mine and left it in the trunk. Even fits in the little point.
'98 S70 T5
2016 Chevy Cruze Premier
Has thanked: 1611 times
Been thanked: 4072 times
They don't even put them on the cars they build in Austria...
:lol: :lol: :lol:
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
At some point rspi posted of video showing how his spare tire jack actually failed with out him noticing. It looked like the stationary threaded component (made of plastic) had stripped and allowed the car to come down slowly. Why would anyone manufacture a vital component out of plastic....
cmblackburn
Year and Model: 1998 S70 T5M
Been thanked: 7 times
Post by cmblackburn »
The P80 ones are pretty awful. I've broken 3 98 jacks unexpectedly just taking wheels off, the things just bend over and collapse. It's terrifying.
I now carry around the jack and toolkit from my sister's totaled 01 Ford Escape, as the lug wrench doesn't bend like play-doh (like the Volvo ones do) and it's actually a pretty stout jack.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Why worry about the jack? Volvo doesn't even put spare tires in the cars any more.
enotslim
Year and Model: 2004 XC70
Has thanked: 71 times
Been thanked: 16 times
Post by enotslim »
I need a floor jack but storage space is very limited. It would be great if the 2 ton compact trolley jack from harbor freight (#62117 for example) actually works. Anyone have experience with this jack? It's a matter of space, not price. If it leaks I can replace the o-rings as described by CN90 at Fix your floor jack. (Good jack stands seem more important than a fancy jack.)
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
jblackburn
enotslim wrote: 10 Dec 2017, 02:52 I need a floor jack but storage space is very limited. It would be great if the 2 ton compact trolley jack from harbor freight (#62117 for example) actually works. Anyone have experience with this jack? It's a matter of space, not price. If it leaks I can replace the o-rings as described by CN90 at Fix your floor jack. (Good jack stands seem more important than a fancy jack.)
It works if you use it relatively infrequently. They're cheap junk and we've had each last about a year, maybe a bit more. Get a jack pad or you'll crush the metal you're using to lift the car.
'98 S70 T5
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
It was my the only jack for 6 years. Zero maintenance. Of course it is cheap and the quality can differ. Of course it is only used to raise a vehicle high enough to fit two jack stands, one 2 ton under front jack brace and another 3 ton under subframe. Wheels choked of course.
The only problem with this jack it is too low for XC, you have to use 2x4. I recently got another HF jack, higher and sturdier, plus a bottle jack, but still use this small red jack pretty much every time I need to take suspension apart.
I found hockey pucks make great jack pads for raising lift - I got a bag of them of Amazon for cheap.
They also fit the subframe pad without screwing up the big bolt if you take a divit out of them with a wood boring bit.
They store wonderfully in the crotch of the floor jack, too.
I got the idea of pucks watching a mechanic raising a King Lear jet..
