06 xc70 vs 09 xc90
I'm considering buying one of these for my wife: 2006 xc70 5cyl turbo or 2009 xc90 3.2. I am partial to the xc90; i hear the 3.2 is kind of dull but reliable (like me) but my wife likes the look of the 70. They both have @100k miles. We would be happy with either but my main concern is durability for the next 100k. Which do you think would be the best bet?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Is the '09 XC90 turbocharged? Perhaps all XC90's are. Turbos like premium fuel.
Service records are king here. Skipped oil changes/cheapo oil are bad.
Both have the more modern AWD system but both (I believe) run happier with matched tires.
Cost of each?
3.2 has a chain. The '06 needs a timing belt yesterday.
Do both cooling systems have blue coolant in them?
Do both drive straight down the highway with the steering wheel straight?
Are the wheels scuffed up?
How do they shift?
I'm in No.NJ and there's a 2008 XC70 NON-TURBO 3.2 w/46K and the bloke is asking $14,500. If I was in the market.....
Cost of each?
How do they shift?
- Has thanked: 2856 times
- Been thanked: 1332 times
Dadvid, Which xc90 to buy first generation that will help. I've got a few Repair Database posts that discuss buying a first gen XC90... most/all lead back to various MVS forum discussions.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The best bet is the car that has had already repairs such as suspension, control arms...done at the main dealer.
The XC90 will cost more in repairs.
I would go with the XC70 (you don't want to hear the "I told you to get the XC70" later on
), only issue I think the AWD was fragile up to somewhere in the middle of 2006, if your had the weaker parts it will fail if not already failed - the car will keep going only the rear wheels won't have traction. The XC70 also needs a timing belt which is not a biggie, a local independent Volvo garage should replace it for less than $500 - the water pump should not be replaced with the first belt.
This is a list of repairs after @100k miles on a S60 - the XC have AWD plus a few others parts that may need repairs on top of it
JRL
- Year and Model: Several
- Been thanked: 16 times
The 3.2 6 is less reliable an engine as the 5 as long as the 5 has been WELL SERVICED.
Toss a coin, SERVICE RECORDS is what's most important considering both have 100K miles
- 1114 Views
Last post by matthew1
- 4354 Views
Last post by ggleavitt
- 10 Replies
- 2847 Views
- 17762 Views
Last post by tabormeister
- 15 Replies
- 5903 Views
Last post by vtl
