First gentleman, I should say that I do not know what brand the previous owner purchased for the replacement of the original radiator.
It's been about 3 years since I originally bought my Volvo, so I figured it was time for a coolant flush. I bought coolant and the necessary tools, since it's pretty simple. I get under my car to unscrew the petcock, and it is not there!
All I see is this tab where the petcock should be. I have attempted to unscrew it, however I cannot turn it more than 90 degrees. Is there a another way I can flush the radiator? If not, is there another way to drain the coolant and replace it? My coolant is pretty degraded and my Volvo is beginning to run hotter than usual.
'98 Volvo S70 Coolant Flush issue
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Be happy your petcock isn't weeping! I don't think i will open up my petcock ever again. It broke once and just don't feel it's worth it.
Just crack open the lower radiator hose clamp and pull it off. It'll be a little messier, but it should be quicker.
Retired:
2015 Volvo S60, T5, 85K
- Has thanked: 311 times
- Been thanked: 817 times
What Marco said - unscrew the clamp on the lower rad hose, get a bucket under there, dislodge the hose, and the coolant will all come pouring out.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Looks like the radiator that was in my Dodge Caliber, you rotate the petcock 90 degrees and then pull on it.
That said, just in case that isn't it, I'd recommend the lower radiator hose...
That's the new Nissens radiator type like mine. It's a 90 degree CCw rotation and pull over the oring resistance. Reverse to reinstall. It probably is one of the few improvements over OEM
Interesting. I searched the forum on topic ' Nissens radiator petcock' and found some folks got the 1/2 turn style back in 2011. In 2013, I got a conventional screwed in petcock which I snapped off , of course.
It looks like I either got old inventory or there was a mix.
I replaced it again in 2017 and it has the 1/2 turn style
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
+1 on removing the lower radiator hose.
Also consider a citric acid cooling system flush before adding new coolant.
M1 10W-30 HM
M1 10W-30 HM
