Weak Brakes on 95 T-5r
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
Re: Weak Brakes on 95 T-5r
tech bleed brakes per Volvo procedure -they definitely feel better but I was hopping to be able to lock them up -does ABS prevent this? Rear rotors are blue'd- past sticking calipers? Most likely I will install new rotors next after ensuring that there are no sticking/heat issues lingering - I use a temp thermal gun for this, definitely a handy tool to have.
- Has thanked: 1836 times
- Been thanked: 1709 times
Blued rotors will reduce the braking efficiency significantly. Time for a new/good used caliper and rotors.
warmblood58
Thanks Neil!
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
When you open the celiper bleeder and pump the brakes, does the fluid flow a lot or just a bit out of the bleeder?
Try opening the bleeder, turn the ignition key to Pos II then pump the brake pedal fast and strong - place a 2" piece of wood under the pedal so it doesn't go to the floor. Repeat at all 4 calipers.
tryingbe
- Year and Model: None
- Been thanked: 26 times
Anti-Locking Brake System prevent wheel lock under braking.warmblood58 wrote: ↑27 Sep 2017, 12:20 I was hopping to be able to lock them up -does ABS prevent this?
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
As tryingbe says, you won't normally feel the ABS working on regular driving. You only feel the ABS kicking in if the wheels are slipping like on gravel. Try driving on a gravel road or long drive and hit the brakes. If you get the pulsing from the brake pedal and the accompanying noises then your system is working.
