no rear wheel drive on 2007 xc70
raquette
Year and Model: 2010 xc90, 2007 xc70
Been thanked: 4 times
Post by raquette »
last winter I noticed when the car called for awd in the snow a flashing light would appear on the dash and the awd would not engage, only had fwd.
I have reviewed servicing the haldex and see that a pump clean, new filter and oil change is a maintenance item.
car has 180k.
So 3 questions:
1. Is it likely that by servicing the haldex the awd will be restored?
2. If so, can the pump be removed without removing the entire drive unit on a 2007? video I watched indicated only a haldex 4 can be serviced without removing the prop shaft.
3. what is the oil to go back in - use only volvo oil?
thanks
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
None whatsoever.
You need to pull the stored codes with VIDA. It can be one of five different problems.
No
Use Volvo fluid, it's very specific
JRL
Post by JRL »
He's talking about his Haldex. Nowhere is there anything about engine oil being discussed
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The haldex/AOC is filled with something most like motor oil. It is not as thick and does not have the distinct stench of rear axle lube. It is not red like ATF and is not as thin as ATF. It is a mid-weight oil with specific additives to modify it for a wet clutch use.
The fluid is available from any of the car makers using that system and it used to be available in a Haldex container.
Borg-Warner bought Haldex 6 years ago and that may have changed the availability of the fluid other than through the car maker parts system.
raquette
Post by raquette »
ok thanks all.
I do not have have a VIDA so will likely take this to the dealer for testing and codes.
If I were to buy this diagnostic tool, what manufacturer/model is recommended?
currently maintain a 2004 xc70, 2007 xc70, and a 2010 xc90.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Post your location in your profile, many of us own the vida software. It will cost you 2 trips to the dealer to buy vida installed on a used laptop and a dice interface, $280. I couldn't imagine working on mine without the ability yo read the codes plus it does a whole lot more.
raquette
Post by raquette »
posted
Has thanked: 1505 times
Been thanked: 3818 times
Crap - just drove by you twice this weekend with a decent reader in hand.
If you make it over east to the den of thieves in Albany, let me know - Ill PM coordinates
