Xc90 won't start
Xc90 won't start
Bought this 05 xc90 about a year ago. Has occasionally given the message "alarm system service required" and the sunroof had never worked.. Haven't had any issue with it. but now it won't start. Turn the key, all panel indicator lights come on but it does nothing. Battery good, changed starter, still nothing. Local mechanic checked and said it was related to security system but was dealer only issue.. Read on here about the security battery pack going dead on these models and causing similar issues. Please help? Thx
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Welcome to the forum
For the alarm thing, just unplug or replace the siren module (google up). The car and the sunroof should work with the module disconnected (at least the S60 model does so), it's just that when the alarm will be triggered, it won't sound.
If the mechanic suggested replacing the starter, he doesn't really know these cars. This part rarely (if ever) goes bad on this car.
From your explication, I assume when this happens, the engine doesn't crank at all. The first thing to try when this happens, have the ignition key in Pos II (it for electrical safety on this specific car, same thing if you happen to replace or disconnect/reconnect the car battery), then jump start the battery from a running vehicle or with a battery booster. I prefer connecting both battery terminals to the cables, just watch out not to touch the cables to the chassis. See if it starts. It may be as easy as the battery is draining over night because of the melted alarm siren module. The car still has power for all the electrics, but the starter won't have enough power to turn over and crank.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 23 times
- Been thanked: 127 times
For sure the alarm module can drain the electrical system if the internal batteries have leaked to the point of shorting out the PCB traces within the alarm module itself. That "the sunroof had never worked" is a good indicator that the module is more faulty than just basic alarm functionality. This will need to be replaced, at this point you're better off with another whole module rather than banking on opening the old one up and being able to fix it.
Perhaps the larger question though is how old the battery in this car really is. I suspect if it's not less than 5 years old, you may have 2 separate issues to attend to. If it's the original battery, it may be time for a change unless it's been properly load tested (not just voltage) and has passed.
In the event you have an issue with the battery, can see here for a few links regarding type and size- http://forums.swedespeed.com/search.php ... d=17009322
Good luck !
Good luck !
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
- ggleavitt
Might give Xemodex https://xemodex.com/us/products-for-volvo/ a call , see if someone can help with troubleshooting. At a minimum, they can do a rebuild and/or exchange if it's really the CEM.
