Hey all im new to this thread but ive been following it for abit. Today I finally got around to tearing into a M4.3 ecu I got at a parts yard and well the mod can work sort of. When activated the front wheels spin a lot with WOT from dead stop but nothing like that from light throttle, light throttle has more of a punch though. Actually the first run I did at WOT up a slight incline resulted in my hood flying up so this hack may result in a new hood lol.
Mod done on a 1994 Volvo 855 Turbo, ECU M4.3 -0261 203 072-.
Parts: ECU M4.3, 1K ohm resistor, 20 ohm resistor, NPN transistor capable of accepting 12-13V.
Ok so to do the hack you gotta open up the ecu and find ground, 12v, b2, b3, and b4.
Solder a 1K and 20ohm resistor (in series) from a 12v source on the board to a voltage regulator to make sure the voltage is under 12v but between 8v and 11v.
Then solder the resistor pair to the base of the regulator and the collector of the regulator gets soldered to pins b2, b3, and b4 on the board ( cut the pins out to wiring harness). One extra thing to do that I diddnt was wire a switch before the resistor pair as to be able to controll the mod as ive already spun tire when not intending to.
I will add photos and a schematic soon.
Defeating the torque limit request on the Volvo 850 Turbo
Defeating the torque limit request on the Volvo 850 Turbo - TCM Signals
- henrysin44
- Year and Model: 1994 Volvo 855 Turbo
- Has thanked: 2 times
- Been thanked: 3 times
Daily driver Black 1994 Volvo 855 2.3L Turbo - manual swapped, turbo swapped, green injectors, custom M4.4 Tune, de-catted, custom two-tone interior, V70R seats & rims
Teal 1994 Volvo 855 2.5L N/A Manual Transmission (the back up daily and parts car) - Runs and Drives but the engine knocks
Silver 1997 Honda CRV 2.0 AWD - its in a very sorry condition, but drives
Silver 2003 Subaru Forester 2.5L N/A AWD - Leaks everything
- henrysin44
henrysin44 wrote:Hey all im new to this thread but ive been following it for abit. Today I finally got around to tearing into a M4.3 ecu I got at a parts yard and well the mod can work sort of. When activated the front wheels spin a lot with WOT from dead stop but nothing like that from light throttle, light throttle has more of a punch though. Actually the first run I did at WOT up a slight incline resulted in my hood flying up so this hack may result in a new hood lol.
- Has thanked: 2856 times
- Been thanked: 1332 times
Outstanding, thanks Henry. This is a real "proof of concept".
- henrysin44
Thank you! With my 855T manual swapped i could spin tire accelerating in 1st without trying
P.S: Having or not having a voltage regulator has no effect so I wouldn't bother adding it.
- 2383 Views
Last post by waffleshill
- 3941 Views
Last post by Integrexman
- 3947 Views
Last post by goldmandan
- 18 Replies
- 9735 Views
Last post by Orchid70
- 1110 Views
Last post by cn90
