I’ve been looking to find a 2004 - 2007 S60R (seems rare so far) or V70R (impossible to find) with a manual transmission - any advice on what to watch out for?
Buying advice for S60R/V70R Manual Transmission
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Depends on mileage of course. awd working (should not be able to turn the shaft by hand), clogged pcv, worn shock absorbers ($$$), control arms, slave cylinder on manual
- Has thanked: 2864 times
- Been thanked: 1332 times
Yes, manual R cars are rare. You'll need patience while looking. Post a new "WTB: 2004-2007 R manual" topic in Volvo Classifieds forum.
Post questions here or in those topics, whichever makes more sense.
- Manual P2 specific buying topic - that, and
- How to buy a used Volvo - and
- Volvo Buyer's Guide MVS VRD category - and when you find one... VIN lookup
- Know about the 4C shocks on P2 R cars
- jcgirton
- Year and Model: 2006 Volvo S60R
- Has thanked: 2 times
Your V70R looked really nice - I've been reading through some of the links, I've been trying to figure out what can go wrong with the AWD system, (my S60 is just FWD) - people have posted about the angle gear, the part is expensive but people posted directions to replace it and didn't make it seem like it was that bad of a job (please correct me if I'm wrong) - are there any other known issues with it? is the awd system fairly easy to work on yourself?
The manual transmission looks like it had issues with the slave cylinder but it looks like there was a fix for the part so if it has been replaced it shouldn't have any more issues? Also it doesn't look like you can really replace just the slave cylinder, if the clutch was replaced should it have the newer slave cylinder at this point?
- oragex
If they replaced the slave cylinder, they had to drop the transmission so most probably they've replaced the clutch and the pressure plate (another point on the manual transmission, when the slave fails it leak fluid on the clutch but also on the pressure plate which must be replaced). If the repair was done recently, test well the clutch. If they didn't replace the pressure plate, good chances are it will need replaced. And yes, along with a clutch job on this car the slave must be replaced because even Volvo replacement slaves are known to sometimes fail again (it was a weak design)jcgirton wrote: 18 Nov 2017, 08:57 Your V70R looked really nice - I've been reading through some of the links, I've been trying to figure out what can go wrong with the AWD system, (my S60 is just FWD) - people have posted about the angle gear, the part is expensive but people posted directions to replace it and didn't make it seem like it was that bad of a job (please correct me if I'm wrong) - are there any other known issues with it? is the awd system fairly easy to work on yourself?
For the awd there are several videos on Youtube, it'll give you a great idea about the repair
Don't forget about the extremely expensive 4C struts/shocks that go around 100k miles or so
- Has thanked: 312 times
- Been thanked: 818 times
Yes there are several other wear items in the AWD. Angle gear is the most common, and usually the collar goes out with the angle gear.
Here's an 05 S60R manual in Chicago, condition appears decent but no mention of suspension work done yet ... https://chicago.craigslist.org/chc/cto/ ... 01962.html
- 10 Replies
- 1090 Views
Last post by Ethan5150
- 15 Replies
- 3628 Views
Last post by tryingbe
- 1486 Views
Last post by speedyt5
- 1237 Views
- 2087 Views
Last post by neworleans
