Fall 2017...the tale of the Noisy Pig Topic is solved
Has thanked: 1611 times
Been thanked: 4072 times
Hopefully funny story on my 1999T5M
I finally got around to chasing my bad growling CVVT exhaust, replaced the hub, retimed it with help of Wizechatmgr, and all well, right?
Well, still noisy...now I hear alternator rattle and growl through my pipe. Alternator rebuilt 25k ago, do I ordered a new one from FCP, installed it. Nasty game of alternator Tetris for 45 minutes getting it out, not too bad going back in.
All set? Still noisy...now it's the PS pump. I have a spare from my parts car, so in it goes. Easy job up top.
All. Set?
Well..now the AC compressor bearing is noisy...even with the clutch disengaged.
Good news? I've run out of engine accessories.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Sheesh... It seems like you've found yourself a white whale, or a KER-FLUNK! :)
Do the 99s have the same accessory belt tensioner as the 98s?
Retired:
2015 Volvo S60, T5, 85K
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
You might really make it mad!
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
theWIFES_S70 wrote: 17 Nov 2017, 06:50 Sheesh... It seems like you've found yourself a white whale, or a KER-FLUNK! :)
No - the 'bastards' went to a new routing..I think. AC compressor changed, tensioner went to a 14mm bolt.
I just spent time searching for the 'short serpentine belt' thread to see if I can run my car without AC until I do the compressor - maybe in the spring, but couldn't find it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
abscate wrote: 17 Nov 2017, 07:55I just spent time searching for the 'short serpentine belt' thread to see if I can run my car without AC until I do the compressor - maybe in the spring, but couldn't find it.
2005 volvo s60 2 5t awd ac compressor bypass belt - that it?
Also -> Amazon link
It is but there is both a chassis break and the tensioning problem to understand.
June
Post by June »
abscate wrote: 17 Nov 2017, 10:53 It is but there is both a chassis break and the tensioning problem to understand.
What about putting one of those dummy wheels in place of the compressor? I know for Ford at least compressor replacement wheels are made to delete the compressor. Maybe the parts store may have them for whatever compressor Volvo uses. Have you checked? June
My Volvo cars owned
1996 960 ordered
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
If it's the outer bearing on the compressor (by the clutch) I believe this one can be serviced without having to evac the system. That said, I can totally understand wanting to just run a short belt in the interim.
2023 Lexus RZ450e -66k
wizechatmgr
Also, I have a nearly new condition Dorman PS pump sitting in a box if you want to roll the dice... That was the one I picked up on Amazon as a return for ~$20
Might be a gift horse I can't resist poisoning in the mouth and then flogging it
