Hi All-
I guess I didn't look very closely at my thermostat housing on my 2004 V70 2.5T, but I purchased a new one/upper rad hose recently. When I popped the hood today to go to replace it, I noticed there's an additional small rubber tube coming off the brass nipple of the thermostat housing- does anyone know what the part number for this is? I can't seem to find the hose on any diagram- even in Vida.
Here's the thermostat assembly- you can see the brass nipple where the small hose connects:
https://www.ipdusa.com/products/7007/11 ... -o-gasket
Thanks!
2005V70 2.5T What is the small hose on thermostat housing?
- Been thanked: 504 times
That small hose goes from the PCV pipe coolant system ---> tstat nipple.
That small hose is part of that convoluted PCV-Coolant pipe, PN 30650578 (about $180 or so).
If you are concerned about that small hose, then use a generic heater hose at local auto parts store.
Get the Gates brand hose.
On the other hand, you can re-use it, that hose rarely goes bad before 200K miles.
When I did my tstat in the 2005 XC90 2.5T, I re-used that small hose, you can see it in the DIY I wrote below:
DIY: 2005 Volvo XC90 Thermostat + ECT without removing PS Pump:
viewtopic.php?t=79031
- Been thanked: 4068 times
Be really careful working around that end of the PCV, the vacuum connection is plastic and will snap easily, especially if the part is 13 years old
