brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by brunocerous »
Thanks for the oil cap gasket suggestion, everyone!
On my '98 V70 at 156k miles, i remember the oil dipstick was smoking. When my brother and I replaced the PCV, the hoses were in fact clogged. I'm now hoping the '00 V70 doesn't need the work yet. I've still got a coolant system refresh and a timing belt replacement in mind.
Update on the brake noise: Even though I had torqued the bolts on all four wheels to 100 ft/lbs, the right front had become loose during my test drive. One bolt was even hand-loose! The lack of a retaining pin/screw in the rotor made it a PITA to align and get the new rotor flush with the hub — and it gave me a false torque reading. Scary, but it seems ok now, and I'm glad it was a short test drive.
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
The wheel guide pin should hold the rotor against the hub. Is yours missing?
I usually use one wheel bolt to hold the rotor in place, opposite the guide pin, when I reinstall everything.
volare
Year and Model: 1999 V70R
Has thanked: 59 times
Been thanked: 4 times
Post by volare »
Today, I opened the hood, stared at the misfiring engine for a few minutes, thought about swapping things around to see if the problem stayed in cyl 5 or travelled, and closed it again. Major case of the fuggits.
'99 V70R 180,500+ (FOR SALE)
'06 Baja
'77 Aspen
'99 Honda Rebel
~The Hooptie Herder~
brunocerous
bmdubya1198 wrote: 26 Nov 2017, 07:58 The wheel guide pin should hold the rotor against the hub. Is yours missing?
Yes, it was seized and snapped when I tried to remove it. I did end up using a couple of wheel bolts to hold the rotor on but it shifted when I took it off to get the wheel back on. I'll have to find a screw extractor small enough to get it out. Fun!
brunocerous
volare wrote: 26 Nov 2017, 11:23 Today, I opened the hood, stared at the misfiring engine for a few minutes, thought about swapping things around to see if the problem stayed in cyl 5 or travelled, and closed it again. Major case of the fuggits.
Been there!
That was me with the turbo replacement on my old 2001 Saab 9-5. It only took me 2 years to start it back up again! (Then less than a week to burst the lower radiator hose.)
Has thanked: 1500 times
Been thanked: 3812 times
brunocerous wrote: 26 Nov 2017, 11:37
You can just leave it in and use a stainless steel m6 cap screw there. Lube threads and just hand tight after you bang rotor firmly against the hub.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Went to the car wash and cleaned the front wheels last evening. They had enough brake dust to almost match the black paint on the car... Rear wheels (as always) had no real dust. Good times!
bmdubya1198
The nice thing about my ceramic brake pads is that there is virtually no dust, front or rear. And they're cheap-o Rock Auto Centric pads, too!
Hopefully when I upgrade to Akebono or EBC the dust will stay like it is.
Rustyprelude
Year and Model: 1995 850 T-5R
Post by Rustyprelude »
I finally pulled a bunch of stuff out of my dash behind my radio. Turns out I need to put the blue adapter back in, since its for the CD changer. Not pictured is a mini-coax cable that runs to the antenna in the rear window. Anybody know what this stuff is for?
bmdubya1198
That's all aftermarket, for sure. None of that is original.
