It'll likely be a couple hundred bucks for installation. Most shops would prefer to drop the whole subframe, which is technically the right way and it makes it easier to remove the old bushings.clifford06 wrote: ↑28 Nov 2017, 15:02 Greetings. I have to say that mrbrian200 hit on a major issue I've had with this car. It does have a wandering ride and "following road grooves " type of feel . Never thought sub mounts could be a cause. My mounts are weathered and cracked. Doing the inserts would save few bucks. Any ideas of what installation of mounts might run ? Sway bar bushing probably due for replacement.
The other method is to do one corner at a time and rely on the other three to support the subframe.
