Hi everyone,
Since almost 2 years, I'm the proud owner a 1996 850R wagon with 226Mkm, I really love this car and I want to keep it till the end of times!
I'm wiriting here because I have a weird belt/pulley/bearing(?) noise on cold starts, the noise completly desapears after warming up.
I found on the Internet a video of a car with the exact same noise I have (@arround 0,26sec) ...
Any thoughts?
Thanks!
Justin
Belt/pulley/....noise?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Sounds like a bad bearing... In his case he had a bad belt as well...
2023 Lexus RZ450e -66k
- Has thanked: 317 times
- Been thanked: 531 times
Looks to be a bad tensioner (or another pulley) in the video. Does your timing belt walk on the pulleys like that?
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
If you take the belt off, or even just loosen it you could check for play in the pullies. Would be a dead giveaway.
Otherwise you can use a mechanics stethescope on each pulley and try to ID it that way (be careful the end doesn’t get caught in the moving belt).
Whichever pulley is bad I’d do a tensioner idler pulley kit while you’re in there.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
A cheap trick to find out what making the noise is spraying some water on the belt while it's squealing. If the squeal goes away, you know its the belt. If it remains, then you know its a pulley. Then spray a bit of water on each pulley to determine which one it is. Now that belt moving all around like that is a different issue altogether.
- 1633 Views
Last post by XC70Rider
- 545 Views
Last post by oragex
- 2369 Views
- 2006 Views
Last post by Ozark Lee
- 5245 Views
Last post by LT South Africa
