Rough idle
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Krgree10
Year and Model: 2007 S40
Rough idle
Post by Krgree10 »
Hello, I have a 2007 S40 2.4 that I just purchased about a month ago. I put plugs in it 2 weeks ago and only drove it maybe 5 miles afterwards, and it ran fine. It then sat for 2 weeks before I got in it and it will barely idle and is very hesitant when giving it gas. Tested the plugs, coils, and injectors- all good. When driving it the engine light flashes and display reads slow down or shift up. The convertor smells terrible and is getting extremely hot. Any help on this would be appreciated.
rigozzi
Year and Model: 2000 s80 2.9 NA
Post by rigozzi »
Wrong plugs, these cars are very partial to the recommended type, I believe that year has a waste spark system and requires double platinum with double electrodes. Try a new fuel filter and cleaning the etm, too much unburned gas in the exhaust will cause the cats to get super hot and even glow. Also check your air filter and turbo intake, mass and maf(turbo boost) sensors. Just from my experience, I'm no pro but probably good places to start.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Read the trouble codes...that and go from there. I also suspect plugs. You might not have to do all the other stuff though.
