2010 XC60 rear brake
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
asummers
Year and Model: many
Post by asummers »
I took my XC60 to my normal non-volvo mechanic to replace the rear brake pads. I was told that you have to use a special scan tool to tell the electronic parking brake to release. They tried with a couple of different scan tools and had no luck. Does this sound right? Is there any way someone other than a dealer service could replace the brakes on a XC60?
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
Tractoman
Year and Model: 850GLT 1997
Post by Tractoman »
I've done mine a couple times and there is no scan tool necessary. You remove the parking brake motors and then screw the piston of the motor back down. Once finished you activate the parking brake one and off a few times and it recalibrates it's position to work correctly with the new pads.
Thanks,
Mike
1997 850GLT
2010 XC60 T6
