Hello,
I have oil leak on a right side of the engine. Hard to tell where.
I have just taken out the plug from the VVT wheel and found out there is a lot of oil. Is it normal that there is oil or it is indicating that the hub is leaking?
VVT Hub
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Oil at the cam gears may meant damaged seal from clogged PCV box
How many miles on it? Have you owned it for long time?
- Has thanked: 1497 times
- Been thanked: 3809 times
Lots of oil Inside a CVVT hub, it’s oil pressure that moves the hub relative to cam
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 479 times
The cam seals can leak if crankcase has pos pressure instead of vac. Do the glove test over the oil fill csp, see youtube vids if you dont know how.
If it has good vac then it's likely the cvvt hub is leaking.
To delve further I think you need the camshaft locking tool. I only watched part of this video. It gives a general idea.
- SuperHerman
- Been thanked: 207 times
Oil there is totally normal. If I recall the shop manual even says to get a rag ready.
How many miles? Your cam seal may be tired and due for a replacement. May want to do all four while you are at it.
marcus
- Year and Model: S60 2002
- Has thanked: 12 times
I was doing the cylinder head gasket recently. I found that on the exhaust shaft there was no seal on the other side to timing belt. Is it normal? The car was only once before at the shope for work realated to the head when the bolts on the VVT went loose. During the cylinder head assembly I installed the seal. Was I correct?
- jonesg
Some of them don't use cam seals, don't know which yrs but if you didn't have a problem with no seal I'd keep it that way.marcus wrote: ↑05 Feb 2018, 01:59 I was doing the cylinder head gasket recently. I found that on the exhaust shaft there was no seal on the other side to timing belt. Is it normal? The car was only once before at the shope for work realated to the head when the bolts on the VVT went loose. During the cylinder head assembly I installed the seal. Was I correct?
marcus
It could be my case. The head had rubbered cup which actually had some leak. But the head has drains in the casing the same way as by the other seals. I do not think he seal will create problem.jonesg wrote: ↑05 Feb 2018, 21:06Some of them don't use cam seals, don't know which yrs but if you didn't have a problem with no seal I'd keep it that way.marcus wrote: ↑05 Feb 2018, 01:59 I was doing the cylinder head gasket recently. I found that on the exhaust shaft there was no seal on the other side to timing belt. Is it normal? The car was only once before at the shope for work realated to the head when the bolts on the VVT went loose. During the cylinder head assembly I installed the seal. Was I correct?
marcus
I did the glove test and it was ok. I think that the VVT is leaking.jonesg wrote: ↑03 Feb 2018, 10:55The cam seals can leak if crankcase has pos pressure instead of vac. Do the glove test over the oil fill csp, see youtube vids if you dont know how.
- 4723 Views
Last post by LT South Africa
- 3512 Views
Last post by jimmy57
