Hello. I just had a local mechanic replace the clutch on a 2007 S40 at around 100K miles.
Upon driving the car through a heavy rain storm and then parking on my driveway, I noticed oil drips along the driveway and under the car. I jacked the car up and removed the debris panel under the engine and took the attached picture.
The picture is taken at the very front of the car with camera pointed to the rear of the car.
Can someone confirm that this is probably just a bad seal when the mechanic closed up the system at the end of the clutch job?
I'm going to take it back to the mechanic and I just wanted to be armed with as much info as possible.
Thanks very much for the help.
S40 oil leak after clutch job (with pic)
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Going to assume there was no leak before the clutch replacement.
So there'd be 3 possibilities. Rear main seal, front transmission seal and slave cylinder. Though I'm not sure if an '07 has integral slave cylinder. Is I it inside or outside of the bell housing?
Did the mechanic replace the rear main seal when he did the clutch?
If yes, I'd say he either installed a bad seal, or didn't install it correctly.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
That's good.
I once installed a new axle seal on my dad's Civic that was no good out of the box. The seal, not the Honda.
It happens.
It happens.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- 14 Replies
- 3233 Views
Last post by jeffsws
- 957 Views
Last post by difflock54
