PO340 code--cam shaft position sensor
yabadabadoo1026
Year and Model: 2001
Post by yabadabadoo1026 »
this 01 s60 with just 130M miles is killing me with multiple codes
first a 420 suggesting catalyst system--------car running fine with that code/ refused to believe I needed another converter but willing
to put one on since an universal that needs cutting and welding isn't that much----------still it said "system"
which may not mean new converter necessarily
then a PO340 cam shaft position sensor bank 1-----------from what im reading that may explain it cutting out on me when driving
and very difficult to start and with horrible gas milage
then just yesterday a po304----------misfire--------I put a new plug in and no help-------I switched the coil for the offending cylinder
with another to see if I get a different code to confirm I need another coil/ no verdict yet
WHERE IS THAT CAM SHAFT POSITION SENSOR BANK 1-------------ive looked all over the internet and cant get a conclusive answer---one YouTuber says its on top of the transmission on drivers side best accessed taking the air cleaner housing and ive seen other comments its on the block / one said under the cover that accesses the coils and plug ( read that after I had already been in)
does the bank 1 suggest there is more than 1 on the car like the O2 sensor--------------is it possible that PO340 issue is causing the cylinder misfire
thanks for the help guys---brand new to the forum
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
yabadabadoo1026 wrote: 18 Feb 2018, 16:42 this 01 S60 with just 130M miles is killing me with multiple codes
It's right on the end of the camshaft, opposite to the timing belt end.
I got a code and found the 2 torx bolts were loose.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Bank of cylinders.
With a inline engine there is only one bank of cylinders. Some of the newer inline engines with dual variable valve timing (VVT) use bank 1 and bank 2 on the only bank of cylinders.
With a V6, V8, V10 or V12 there are two banks of cylinders.
P0340 can be the cause of P0420 and P300 - P0306.
Fix the P0340 first.
Active
Past
yabadabadoo1026
thank you gentlemen------------the 420 Catalyst System was on long before the PO340 and the PO304 started yesterday--------sure would love it if the 340 fix corrected the other codes but I haven't been lucky on anything in a long time
car started intermittently cutting out on me when driving as if the key was turned off, then it would start back up. But it is very difficult to crank. The cylinder miss im not finding ( unless my 304 becomes a 305 tomorrow meaning coil pack bad) now makes it undriveable. I know those who know meters know how to check them out but I don't do meters well so ill replace and just hope since that little nothing costs too much / seems an easy replace once I find it. Maybe ill get lucky too and find 2 screws backed out but I doubt it-----don't know how that could happen
RickHaleParker
Check the cable and connector first. The ECM is not hearing the CMP or not well enough. In short the CMP is not talking or you got trouble on the line.
(P0340) ECM-3000 Camshaft position (CMP) sensor. Faulty signal
Diagnostic trouble code (DTC) information
D2800350 Condition
Diagnostic trouble code (DTC) ECM-3000 is stored if the control module does not register a signal from the camshaft position (CMP) sensor or counts too few flank changes during 5 crankshaft revolutions and / or 2 seconds has passed.
Substitute value
Uses the engine speed (RPM) sensor if it functions.
Possible source
  • Signal missing
    open-circuit in the signal cable
    short-circuit to ground in the signal cable
    short-circuit to supply voltage in the signal cable
    defective camshaft position (CMP) sensor.
Fault symptoms
None.
Active
Past
FREEBUSINESSES
Year and Model: 2005 XC90
Been thanked: 3 times
Post by FREEBUSINESSES »
Anyone have a guess at why I get PO0340 only after shutting down engine and starting again. I can drive hundreds of miles with so svc light or code, only when I stop and start engine. I replace cam sensor, same issue? XC90 2.5T runs great, get great gas mileage, so no indications of problem other than code consistently coming on after shutting down and starting again.
jonesg
Post by jonesg »
FREEBUSINESSES wrote: 29 Jun 2020, 21:10 Anyone have a guess at why I get PO0340 only after shutting down engine and starting again. I can drive hundreds of miles with so svc light or code, only when I stop and start engine. I replace cam sensor, same issue? XC90 2.5T runs great, get great gas mileage, so no indications of problem other than code consistently coming on after shutting down and starting again.
The fault was there whilst the engine was running but the computer compensated.
Once shut down the fault is logged and you get the code.
If you moved a coil, wait until you see the results of that, be methodical, don't swap 3 things at once.
FREEBUSINESSES
Thanks, I simply replaced both fuel pressure sensor, no change, pressure good, then cam sensor, not change, so usually codes will happen while engine is running, but in this case, only when turning off and on again.
Thanks
jonesg
Post by jonesg »
On mine, 04 v70, bank 1 is the intake cam, closest to the radiator.
If something is wonky on that circuit the ECM will dump fuel in the intake and produce O2 sensor fault codes.
Using vida it showed the CVVT cam solenoid was reacting slow, cause was thick dino oil.
Low oil pressure caused a slow cam solenoid reaction.
Using VIDA I was able to see the slow reaction.
Possible causes listed in VIDA said low oil pressure, wrong oil etc.
I changed to synthetic oil and it cleared up.
Without VIDA you could throw parts all day long and not know what the cause is.
VIDA on an SSD drive along with the DICE interface cost $200, use your own laptop.
Called VIDA 2 GO, it plugs in the USB socket.
https://www.facebook.com/DaveLeachVIDALaptops/
FREEBUSINESSES
I have a PO343 code and is this the exhaust cam as I recall? Of course this is the most difficult to replace, but replaced the intake cam sensor just in case, didn't change issue. Engine has never run better, but throws code every time I shut off and restart, never comes on while driving hundreds of miles. It is 05 XC90 2.5T engine.
