2003 S60 Starts then dies immediately(Clean PEM 8634953) Topic is solved
Delirious
Year and Model: '00 S70 '03 S60
Has thanked: 3 times
Post by Delirious »
No pressure at the rail, replaced the fuel pump (steel tank version), checked fuses.
What am I missing?
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
Has thanked: 1505 times
Been thanked: 3818 times
Search under ' pump electronic module' in this forum for the recent thread on how to troubleshoot the fuel pump control on P2 cars. Ignore all the P80 fuel pump relay threads, this one is different n
Kudos for troubleshooting with data rather than guess work. You have isolated it fuel delivery quickly
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Delirious wrote: 25 Feb 2018, 22:19 No pressure at the rail, replaced the fuel pump (steel tank version), checked fuses.
What am I missing?
If it's a mechanic who replaced the pump I'd go back and ask him to install back the original pump because aftermarket pumps can become additional problems. Fuel pumps never fail on these cars like on a Honda or Ford. The only time when they fail are when the aftermarket pumps are installed
As in the comment above, check the PEM for corrosion, it's located on the right side of the car just on top of the fuel tank, you can reach/remove it by hand I think it's secured with a bolt. Look for corrosion and replace if needed with used non corroded unit from Ebay or scrap yard.
If that doesn't work may look into the FPS fuel pressure sensor, but much less probable.
Delirious
Post by Delirious »
Thank you for the quick reply's. I have replaced the fuel pump with a genuine Volvo OEM Bosch pump from a '05 salvage car, not realizing that there may be other parts affecting fuel pressure such as this pump electronic module. This part among others did come up during my google searches when replacing the fuel pump did not resolve the starting problem, however the location was described as truck spare tire right side. I will look for it at the top of the tank as suggested above.
Thank you! :D
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
oragex
Post by oragex »
Welcome, the PEM is an easy replacement and can be find on scrapyards on cars that had it already replaced (was a very common fault on metal fuel tank cars). A spare FPS is also easy to remove, turbo and non turbo have different sensors and the sensors were also updated
http://forums.swedespeed.com/showthread ... L-Clearing
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Delirious wrote: 26 Feb 2018, 10:22 the location was described as truck spare tire right side. I will look for it at the top of the tank as suggested above.
Thank you! :D
They were originally placed at the top of the tank at the factory. That location turned out to be problematic because of corrosion. If/when they failed and a dealer replaced it they moved it to the trunk. If you pull one out of a salvage vehicle, look for one that was moved to the trunk. I would snag the (dealer added) harness that connects between the connectors at that original location and facilitates moving the PEM to the trunk. Take careful note how the harness is routed so you can put it in your car without risk of damage/pinched wires etc. Don't forget the velcro that attaches the PEM to the body of the car inside the trunk. If you're careful you can peel it up and reuse being mindful not to contaminate the adhesive with dirt/fingerprints etc. It will stick to, but release from any smooth plastic you happen to have on hand.
In the thread referenced above, I pulled my PEM out and dumped about a palmful of Aluminum corrosion out of it. I cleaned with contact cleaner and reinstalled. Ive driven it for about another 1000 miles with a brand new PEM in the box in the back.
It might not be a bad PSA to clean the PEM on older P2s as PM
Its an expensive ($350)part, but only 0.314 hours of labor to put in.
mrbrian200
If you pull one out of a car that ended up in a salvage yard due to an obvious total loss collision you're more likely to get a good PEM as the car would have been running at the time of the accident. It's a pretty safe assumption the PEM should be good after a front or side collision.
Delirious
Post by Delirious »
Wow thanks guys, awesome info. with your help we found the PEM, removed it and then I decided to fix it. My son will install it tomorrow morning and will see if the repair was successful. Pictures for others interested in this repair.
'00 S70SE, 287K KM
'03 S60, 168K Miles
'03 Maxima 287K KM
'06 Altima 252K KM
You can back rinse that circuit board with Contact cleaner and see if you move the Al crud off it enough for it to work again
Mine has run a couple 1000 miles after doing that.
