Accelerometer and APS codes
galexie64
Year and Model: 1998 V70 AWD
Re: Accelerometer and APS codes
Post by galexie64 »
RickHaleParker wrote: 23 Feb 2018, 00:58 You might try disconnecting sensors in the lists below and see if the DCTs change.
Thanks for that great info. I will start with disconnecting the sensors one at a time and see what that does to the codes. I will post the results.
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
1964 Ford Galaxie 500XL 2 dr fastback, 390 thunderbird, auto, AC
1970 Ford F250 Custom Explorer Camper Special 390/C6
My Car Blog
Has thanked: 1850 times
Been thanked: 1712 times
Awesome detail and very helpful info Rick!
galexie64
Post by galexie64 »
Codes don't change after disconnecting sensors one at a time. I wasn't sure where the fuel tank pressure sensor is located.
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
Have to double check as it is slightly different to the 99-00. On those it is hard to get to buried forward of the charcoal filter above the fuel tank. Taking a quick look at Vida for a 98 AWD would appear to show it on top of the the fuel tank. I can try to find a picture of my 2000 R from the sub-frame replacement and it should be near there.
Carbon Filter
Carbon Filter
The picture above is looking toward the back of the car and the carbon filter is the rectangular box to the top left of the picture. Under the bottom left as viewed you can see a rusty triangular bracket. This is where the fuel pressure regulator is attached to on my car.
Picture below shows the pressure regulator tucked up under the carbon filter.
Fuel pressure regulator
The 98 may be fitted slightly differently but I don't have a picture for that unfortunately.
galexie64
Post by galexie64 »
I'm going to try and dig into this on Friday.
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
