Accelerometer and APS codes
galexie64
Year and Model: 1998 V70 AWD
Post by galexie64 »
I have two codes that I have not been able to get rid of.
Efi-444 accelerometer signal
Efi-422 atmospheric pressure sensor signal.
I tried swapping out the accelerometer from my parts car but the code stayed on. I'm not sure it the problem is the sensors or the wiring. I need to figure out how to test the sensors.
I did check voltage to the power wires to both sensors and I have the required 5volts. I also checked ohms to the other wires and they are good.
Is there something I could be missing?
How do I actually test the sensors?
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
1964 Ford Galaxie 500XL 2 dr fastback, 390 thunderbird, auto, AC
1970 Ford F250 Custom Explorer Camper Special 390/C6
My Car Blog
Has thanked: 1610 times
Been thanked: 4071 times
Did you clear codes after replacing parts?
The code format is a bit strange, what reader are you using?
They should read either ECMxxxx or Pxxxx
Has thanked: 2207 times
Been thanked: 1852 times
I can't recall but I think there are 3 sensors on that circuit and those are 2 of them. Any of them could be faulty but the accelerometer is not one that often fails. I have had 2 barometric sensor fails.
You need to reset the fault codes as per abscates. note.
galexie64
Post by galexie64 »
I did reset the codes and they keep coming back. I'm using VOL-FCR 1.7.6
I'll try and get to the junk yard to get a couple of atmospheric pressure sensors to try out.
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
galexie64
Post by galexie64 »
I'm still trying to figure out these codes. I pulled an atmospheric pressure sensor out of the junk yard to try out and it didn't fix the problem. I'm not sure if it is a good sensor though. I really need to figure out how to test the sensor to see if it is good. I don't want to spend the money buying a new one and it turns out the problem is the wiring.
Does anyone have the section of the wiring diagram for a '98 turbo car showing these sensors?
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
We don't host these here by agreement with Volvo legal, but they are public on the web if you google them. You CAN post the relevant parts back here without getting us in trouble, we just have agreed not to archive them here.
galexie64
Post by galexie64 »
abscate wrote: 14 Feb 2018, 09:53 We don't host these here by agreement with Volvo legal, but they are public on the web if you google them. You CAN post the relevant parts back here without getting us in trouble, we just have agreed not to archive them here.
Good to know thanks
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
galexie64
Post by galexie64 »
I've still have had no luck getting rid of these codes.
Is there a plug for this harness between the sensors and the ECU that I could pull apart and clean?
1998 Volvo V70 AWD
1984 RX-7 GSL-SE
My Car Blog
Have you checked the ground points? I think the accelerometer has one on the front face of the block low down near the back of the starter motor.
As to the plugs, not sure where/if there is any other than at the items themselves. Still trying to remember what the 3rd item on that circuit was. It may be the high pressure switch on the AC.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
You might try disconnecting sensors in the lists below and see if the DCTs change.
EFI-444 Accelerometer. Signal too high. Permanent fault
Diagnostic trouble code (DTC) information EFI-444
A2300538 Condition
If the engine control module (ECM) senses that the DC signal from the accelerometer has changed its mean setting (2.5 V) to more than 3.5 V or less than 1.5 V, diagnostic trouble code (DTC) EFI-444 is stored.
Substitute value
none.
Possible source
Signal too high:
  • short-circuit to supply voltage in signal cable
    open-circuit in signal cable, ground lead or power cable
    short-circuit to ground or supply voltage in power cable
    contact resistance in terminals
    short-circuit to ground in air conditioning (A/C) pressure sensor
    short-circuit to ground in fuel tank pressure sensor power cable
    short-circuit to ground in atmospheric pressure sensor power cable
    defective air conditioning (A/C) pressure sensor
    defective atmospheric pressure sensor
    defective fuel tank pressure sensor.
    defective accelerometer
Signal too low:
  • short-circuit to ground in signal cable
Fault symptoms
can store misfire diagnostic trouble codes (DTCs) when travelling on an uneven road.
EFI-422 Atmospheric pressure sensor. Signal too high. Permanent fault
Diagnostic trouble code (DTC) information EFI-422
A2301616 Condition
Diagnostic trouble code (DTC) EFI-422 is stored if the engine control module (ECM) receives a signal from the atmospheric pressure sensor corresponding to a height above sea level of over 6.500 m (low signal) or under 780 m (high signal).
Diagnostic trouble code (DTC) EFI-422 is stored if the signal is unstable for 25 seconds (sporadic signal).
Substitute value
the engine control module (ECM) adopts a height of 0 m above sea level.
Possible source
Signal too high
  • short-circuit to supply voltage in the signal cable
    open-circuit in signal cable or ground lead
    short-circuit to supply voltage in the power cable
    short-circuit to supply voltage in air conditioning (A/C) pressure sensor power cable
    short-circuit to supply voltage in fuel tank pressure sensor power cable
    short-circuit to supply voltage in accelerometer power cable
Signal too low
    short-circuit to ground in power cable
    open-circuit in power cable
    short-circuit to ground in accelerometer power cable
    defective accelerometer.
Signal sporadic:
  • loose connections
Fault symptoms
poor performance at high altitude
can cause starting problems at high altitude.
Active
Past
