Installing Vida 2014D for the first time Windows 10 Home
This topic is in the MVS Volvo Repair Database » How To Install Vida On Windows 10
AaronsVolvo
Year and Model: 1999 V70
Has thanked: 11 times
Post by AaronsVolvo »
Hi all, I recently bought a Dice with Vida software off of ebay. I am not in any way shape or form a computer person. When I ordered my Vida+Dice I had no idea what I was getting into(yes I know, my own big mistake!).
I have a windows 10 Home laptop. Is it possible at all to make Vida work on this?
I mainly just need to use the device long enough to fix code P0722 Output transmission speed sensor on my "99 V70. I need to find out which sensor for sure is bad and when I replace the sensor I need to reset the code. I do not need Vida+Dice long term as I will only own this car long enough to get it running correctly in tip top shape.
Any and all help is greatly appreciated, I am sorry for my computer ignorance :)
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Yes you can get it to work on Windows 10 but use the 2014D RePack and the 2099 patch I pointed you to. Not the software that came with the DiCE.
Active
Past
AaronsVolvo
Okay so Rick helped me get VIDA going, I have made it to the point where I can log into Vida with “1”, enter my cars info, but DiCE is not connected.
I can go onto my computer, find DiCE and test it through the DiCE diagnostic tool.
The DiCE will test “okay” for every test I can run, sometimes it will say “self diagnostic tool not okay”
Then test “not okay”
But even when it does test “okay” I cannot get it connected to Vida.
What have I missed?? And why will it only pass the “interface test” sometimes. One minute it will one minute it won’t...then it will again.
I had the keys in the ignition of my car turned to II.
AaronsVolvo
Here’s two pictures I took of my screen...
AaronsVolvo
Pic 2
RickHaleParker
Try reinstalling the DiCE Software from the RePack.iso :\3PP\Products\DiCE\
Reboot after install.
If reinstalling does not work try this.
Partner group for North America is AME, 2 will log you straight into the AME Partner group.
AME = North America
EUR = Europe
INT = International Misc
NOR = Nordic Countries
Logins
admin: Administrator
1: International Arabia and China
2: North America
3: Nordic Countries
4: Europe & International except Arabia and China.
Active
Past
AaronsVolvo
I have already tried that link, when I type “regidit” a pop up says “cannot be found”
I have also tried searching DiCE, Vida, systems and a few others, same pop up.
AaronsVolvo
Isn’t there supposed to be a tab here for me to add the Dice?
AaronsVolvo
I tried reinstalling VIDA to see if something was wrong there.
I got a pop up, I may have gotten this before. Would this stop DiCE from connecting to Vida?
RickHaleParker
Your trying to install the Vida that came with the DiCE hardware or you ran script 5 on the 2014D_RePack which my install instructions say not to run.
We know the RePack works with Windows 10 Home. Mr Brian 200 and I both tested it on Windows 10 Home. The Vida that came with came with your DiCE hardware requires Windows 7 Professional, that is why I pointed you toward the Repack. The RePack has modifications that let one install Vida on Windows 7,8 & 10 any version except 7 starter.
Take the Vida disk that came with the DiCE hardware and put it up on a high shelf and forget about it. Do everything from the 2014D_RePack.iso
1. Install and work from the 2014D_RePack.iso per my instructions.
2. You misspelled "regedit" (registry edit). regedit is on your system. Watch what your do in the Registry Editor, If you do make any changes, take your time and make sure you do it right the first time.
Active
Past
