Hello again,
One of the things i noticed on all of my cars in the past is that after a while the oil turns dark. It starts out clear where you almost cant see it on the dip stick, then eventually well under 3k miles it starts to turn dark. I know it cant be 'bad' oil.
Any ideas why it turns dark?
Synthetic Oil Harmful?
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Re: Synthetic Oil Harmful?
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
See June's oil thread in the general section for some thoughts on that. I've never really seen that kind of darkening using synthetic oil myself and June seems to confirm that after switching. My oil mostly just seems to slowly fill up with soot and other contaminants rather than change colour itself. If the colour is relevant for actual properties though is another matter.MrAl wrote: ↑03 Apr 2018, 05:56 Hello again,
- Rattnalle
Pretty much nobody is an extreme use case. I mean how many minutes in a year do you actually drive the car full throttle? Not they many even if I actually do try to when I canabscate wrote: ↑03 Apr 2018, 04:58the rest of us just need to read the world least read book![]()
If you have normal use patterns this is the easy route. Our oil change places here try to sell everyone that they have extreme use and then push 3000 mile changes which, if the owners fix oil analysis, would find unecessary.
The folks here with very low mileage patterns might want to do oil analysis if it gives them piece of mind.
I’ve changed my low miles VW to a 2 year interval so I’m running out of used oil to sell...
I'm guessing cold starts and short driving distance is much more extreme but then you'd still hit the time limit for the oil changes with low milage and be fine.
- Has thanked: 304 times
- Been thanked: 517 times
The brake fluid is still up for grabs, right? I hope so, I can't stand to spend $4 on that Prestone stuff from Walmart.
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
We carry a low-priced all-purpose mixture of all kinds of refurbished automotive fluids: coolant, brake fluid, transmission oil, engine oil, and power steering fluid.
Disclaimer: It can be used on any self-propelled vehicle in any application (except as a windshield washer fluid)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- Has thanked: 1506 times
- Been thanked: 3818 times
Harsh brownies....
- regent
Those have not yet been considered for approval by the FDA, not in the CONUS
2015 BMW 335i
2015 BMW 335i
- MrAl
Hi,Rattnalle wrote: ↑03 Apr 2018, 06:44See June's oil thread in the general section for some thoughts on that. I've never really seen that kind of darkening using synthetic oil myself and June seems to confirm that after switching. My oil mostly just seems to slowly fill up with soot and other contaminants rather than change colour itself. If the colour is relevant for actual properties though is another matter.MrAl wrote: ↑03 Apr 2018, 05:56 Hello again,
Do you have a link to that? Sounds interesting. I'll try to find it too.
- Rattnalle
Here it is: viewtopic.php?f=4&t=84023MrAl wrote: ↑04 Apr 2018, 10:00Hi,Rattnalle wrote: ↑03 Apr 2018, 06:44See June's oil thread in the general section for some thoughts on that. I've never really seen that kind of darkening using synthetic oil myself and June seems to confirm that after switching. My oil mostly just seems to slowly fill up with soot and other contaminants rather than change colour itself. If the colour is relevant for actual properties though is another matter.MrAl wrote: ↑03 Apr 2018, 05:56 Hello again,
- MrAl
Rattnalle wrote: ↑04 Apr 2018, 10:14Here it is: viewtopic.php?f=4&t=84023MrAl wrote: ↑04 Apr 2018, 10:00Hi,Rattnalle wrote: ↑03 Apr 2018, 06:44
Hi,
Thanks much.
What do they mean by group 3 and group 5 oil?
- 2712 Views
Last post by Uree
- 64 Replies
- 10154 Views
Last post by plumsmooth
