Trying to remember this. If I recall boost is applied by the TCV allowing pressure to be sent to the wastegAte, which keeps it closed.
The 3.5 psi measurement is a calibration pressure applied to the wastegAte which is then set to the closed position following the procedure given in VIDA. Shortening -the rod will mean the wastegAte but opens later
Uh oh, what do I have wrong here ?
1996 855 T5 - Musings on Wastegate Adjustment
- Has thanked: 1506 times
- Been thanked: 3822 times
Re: 1996 855 T5 - Musings on Wastegate Adjustment
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
On the 850s the tcv opens the wastegate by applying pressure.
I recently played with my setup again. Relocated the tcv nearer to the turbo and shortened the hoses a lot. Since then i was able to increase the pretension again and also the boost build up is smoother since the tcv seems to be able to regulate better.
850 T5-R '95 auto
Reviving old topic
Here is the picture of my discontent
Yet people report enhanced Or earlier boosting when shortening the wastegate rod.
hausmeister
that should explain it
850 T5-R '95 auto
Ha!!
Dumba$$ moment.
Im watching this thinking I know all this already - then realize my mistake - really simple one.
WASTEGATE CLOSED = maximum boost
WASTEGATE OPEN = no boost.
So, as the spring and diaphragm age, the Wastegate Adjuster has less tension to close the waste gate, and it stays open and reduces boost. Shortening the rod compensates for the weakness and closes the waste gate like new.
Dumba$$ moment.
Awarded this 9 April in the year of our Swede 2018
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
It could have been worse... You could be the broke guy that makes sure everyone on government assistance gets their benefits - on time even.
- 2780 Views
Last post by Angelofhevn
- 656 Views
Last post by j-dawg
