Has thanked: 1505 times
Been thanked: 3818 times
Re: What did you do to your Volvo today? (now Sticky!!)
Its America - you can buy a car with money collected from turning in cans and bottles, if you drink enough.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 11 Apr 2018, 07:52 Its America - you can buy a car with money collected from turning in cans and bottles, if you drink enough.
Just a few thousand bottles is all you need. Some people around here that can do that in a weekend!
Got my cam sensor swapped out yesterday. Car still hiccups. Time to go bang my head against a wall...
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
Got the M56H flywheel resurfaced. I love me a nice freshly machined surface...
1996 854R | M56H | 16T | 274k | BC, Canada
Nice. Do you lightly oil that after machining to prevent rust?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Or put it in a bag with some desiccant packs (Rice or some damp-rid)
Current Volvos:
FLXC90
Post by FLXC90 »
Finally spent 15 minutes and reinstalled the passenger under dash panel whose tabs I epoxied back in January.
Current Volvos:
sventastic
abscate wrote: 13 Apr 2018, 04:07 Nice. Do you lightly oil that after machining to prevent rust?
I wasn't planning on it, it should be on the car in 2 weeks from now, so if any surface rust builds up I should be able to tackle it with some brake clean and a scotch brite at worst.
FLXC90 wrote: 13 Apr 2018, 16:01 Or put it in a bag with some desiccant packs (Rice or some damp-rid)
Not a bad idea!
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Slayed the CCM-236 Recirc signal too low today. Removed motor, cleaned the grease out of the electrical potentiometer/varistor contacts, lubed the shaft with disc brake grease and reinstalled. Got the error again. Disassembled and moved the motor exactly one tooth out of position towards the opposite direction. Works great. During initial reassembly everything was in the exact position it didn't work at previously. So if you're stuck, try moving that sucker one tooth clockwise. Position of the shaft doesn't seem to matter provided for the most part it is in the middle of the slide area. Let it go to full recirc (I think it was this position) then install the linkage with it pulled tight. Then reinstall glove box support beam and glovebox. Sit back and enjoy your ability to no longer have to smell the outside or inside.
Used VIDA to determine the ECC's perceived motor position. Get a nice clean swipe now.
Note to a specific moderator: no seats were lubed in the repairing of this item or the making of this message. =p
I’ll be right over when the power fails
wizechatmgr
abscate wrote: 13 Apr 2018, 21:15 I’ll be right over when the power fails
You're a day early.
