ECM and ECu are the same.
The error codes generated by the modules are coded by the module reporting them the ECM codes usually have 5 codes for each corresponding P code. This gives you valuable info as to the failure.
98 V70 base P0400 error code
- Has thanked: 1502 times
- Been thanked: 3817 times
Re: 98 V70 base P0400 error code
- Has thanked: 1843 times
- Been thanked: 1710 times
Ok, I get you now. Thanks. Still baffles me how the dealer and the specialist couldn't scan those issues though?
- 298 Views
Last post by Shinotheweevil
- 17 Replies
- 4199 Views
