XC90 2.5T, 3.2 or v8? Looking to buy
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Re: XC90 2.5T, 3.2 or v8? Looking to buy
Post by xHeart »
Being a DIYer, the B6324S 3.2 straight-six appears extremely attractive over B5254FS & B5244T3. I wonder why MVS maverick CN90 did not take on B6324S.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
I agree the B6324S does look attractive if you're shy about turbos and don't need large towing capacity/heavy loads.
xHeart
Post by xHeart »
2013A XC90 with B6324S is a REALLY attractive purchase. PCV itself is simple and fun to work. No timing belt shenanigans.
Will 2014A VIDA DiCE read it?
mrbrian200
xHeart wrote: 17 May 2018, 14:20 2013A XC90 with B6324S is a REALLY attractive purchase. PCV itself is simple and fun to work. No timing belt shenanigans.
It should
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Only worry on the "Short-six" is the READ-rear engine accessory drive. Looking at a large chunk if the drive for the alternator etc goes. And it may not be common, but it has not been unheard of. A friend just asked for info on his early V8 with Slow down or upshift warning (valve body?) I'd go for the 2.5T or a later V8.
Current Volvos:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
Also -> Amazon link
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 23 times
Been thanked: 126 times
Post by ggleavitt »
FLXC90 wrote: 19 May 2018, 18:31 ...early V8 with Slow down or upshift warning...
Barring a valve body issue which may or may not also be a concern, can see this link for a more common reason this message comes up- specific to the V8- http://forums.swedespeed.com/showthread ... -Triangle)
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
FLXC90
Post by FLXC90 »
Thanks for that GG, he says transaxle performance is good, just cured a multi-cylinder misfire condition on new to him SUV. He will be relieved that he just needs to clean his throttle body and put his right foot on a diet!
Current Volvos:
ogatrulle
Year and Model: xc90 2008
Been thanked: 10 times
Post by ogatrulle »
xHeart wrote: 04 May 2018, 08:00 3.2L B6324S is readily available for 2007-2013. However, I've zero knowledge and workings of 6 cylinder. Is it possible to translate my 850 N/A and V70XC experience to a 3.2?
I have a 2008 xc90 3.2 FWD. Been driving it for about six years (35kmi when bought, 120kmi now).
Upside: no timing belt. Downside: the serpentine belt is a PITA. The steering pump and water pump are on concentric shafts on either side of the pulley, so the steering pump has to come out to replace the belt. The V70 steering pumps are easy. The 3.2 xc90 steering pump has several bolts that are difficult to reach and not feasible with a torque wrench, so you'd better have a good feel for tightening. I had the pleasure of learning these details when replacing the water pump whose bearings crapped out at 90k (it appears to be the same ol' water pump that Volvo uses on the 2.5 at al.)
There is also some funny business with the alternator drive which I have not had to learn about (yet).
Lower control arms: upside! you can pull and replace all the bolts without raising the engine!
Headlight design is easy to deal with.
2006 v70 2.5T; 2008 xc90 3.2
