Can you lift a 1998 V70XC?
This topic is in the MVS Volvo Repair Database » Lift a 1998 XC70
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
BULLOGNA wrote: 12 May 2018, 23:07 The answer is yes you can...
I like it. Thanks for sharing, BULLOGNA.
Kara503 wrote: 18 May 2018, 16:46 Anyone know if a similar route could be used to lift a P2 XC70?
Not a direct answer to your question, but there are products out there... Lift your xc70 or v70
Also -> Amazon link
BULLOGNA
Year and Model: 1998 V70 XC
Been thanked: 3 times
Post by BULLOGNA »
You would need to know the rear spring inside and outside diameter and do some home work but I would say doubtful that this way with a spring cup would work but when theres a will there is a way and there is more info on lifting XC70s ..So start measuring
BULLOGNA
Post by BULLOGNA »
So I tried adding these photos a few days back made me some cardboard templates and butchered up these XC 90 struts they add some camber ..So no camber plates have to figure it out .My thought is a diy camber plate 3 bolts thru the strut tower thru a threaded plate in the wheel well and then push out the three bolts in factory strut plate and slot strut plate and tighten bolts in the wheel well ? Or the lower control arms find a longer bolt and some shims / washers and place between control arms and frame will push the lower control arm out ??
Been thanked: 4071 times
Yikes. Not enough structural metal left there. I would run a strength calculation on that thickness to confirm it’s suitable for load.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 23 May 2018, 04:27 Yikes. Not enough structural metal left there. I would run a strength calculation on that thickness to confirm it’s suitable for load.
That was the first thing that came to my mind looking at it. Not much material between the hole and the edge of the bracket.
Has thanked: 2205 times
Been thanked: 1852 times
Yikes that is down right dangerous!
There is a guy that has lifted his XC70 if I recall correctly. I think he posted at one point on either XCforum or IPD website.
I think IPD used to sell a camber adjuster for P80's.
bmdubya1198
I think Kaplhenke sells camber plates. Don't think I've ever seen them on iPd. At least not in the past couple years. https://www.bneshop.com/collections/p80 ... trut-mount
BULLOGNA
Post by BULLOGNA »
Yeah that is just a sacrificial strut I just butchered up to see if the unit would fit in the location down and dirty style .So if I went this route the extra hole would not be there and a extra plate would be welded on
BULLOGNA
Post by BULLOGNA »
bmdubya1198 wrote: 23 May 2018, 08:42 I think Kaplhenke sells camber plates. Don't think I've ever seen them on iPd. At least not in the past couple years. https://www.bneshop.com/collections/p80 ... trut-mount
WoW that looks awesome thanks for the heads up I googled cambet plates and I never spottes those awesome ....
bmdubya1198
BULLOGNA wrote: 26 May 2018, 18:34 WoW that looks awesome thanks for the heads up I googled cambet plates and I never spottes those awesome ....
Kaplhenke is one of those “hidden” sites for Volvo performance parts. It takes some looking around to find him!
