Difficult starting
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 42 times
Been thanked: 28 times
Difficult starting
Post by Cees Klumper »
Hoping for some pointers. Tried the search but could not find my symptoms.
It's a 2008 C70 with the auto-start function (turn the key briefly to the 'start' position, let go and the system is supposed to continue cranking until the engine starts running).
Frequently, when trying to start the car, the starter will engage and spin the engine, but then, before the engine can 'catch', the starter just stops spinning, even though I have the key turned to the 'start please' position. So I have to start over again, and sometimes it takes two or three tries before the starter will spin long enough for the engine to catch and start. This is annoying but, so far, it has always started in the end. I am concerned however that, at some point, it will just refuse to start altogether, also because it seems to be getting worse. I thought perhaps I was not pressing the brake pedal strong enough, but that does not seem to be the cause.
P.s. the starter was replaced with a new one by the previous owner, last year (I have the invoice for that so it seems legit).
Any pointers? I get no codes from my Icarsoft II reader. Immobilizer, loose cables, key fob battery getting weak?
