2001 S60 Any preventive maintenance proposal? Topic is solved
S60 Preventive Maintenance Parts
- Year and Model: Lots
- Been thanked: 128 times
That must mean that Castrol Synthetic 5W/40 is cleaning the engine very well. You had better stick to that oil change interval for at least 4 or 5 changes so you can clean the engine, then later you can increase the interval to something like 10,000kms.
I recently used an IPD non-genuine PCV kit for a 2001 XC70 and I was VERY impressed that absolutely EVERYTHING was packaged in the kit including injector O rings and new crush washers for the 2 banjo bolts on the PCV pipe. Keep this in mind when/if you decide to replace the PCV.
I'm going to try to fit the SIM type keypad in my 2001 V70T5 and see if it still works. The rear of the car is filled with a heavy printer for a few days so I can't take a photo of the rear phone module. I may need your rear phone module if it's up for grabs so don't throw it away just yet.
zoli_m13
- Year and Model: S60 2001
- Been thanked: 2 times
I took a Photo at the left and the right side of the luggage compartment: no phone modul found - sorry!
2001 VOLVO S60 2.0T A/T 245K+ miles
https://goo.gl/photos/jS1z777LDqJSQqPDA
zoli_m13
Out: Total Quartz 9000 Energy 5W40, Mahle O/F, OCI = 4000 km (2500 miles)
In: Total Quartz 9000 Energy 5W40, Mahle O/F
Reason of short OCI (targeted: 6K miles) is the cleaning process.
zoli_m13
No visit here for long time ago - almost 1 Year.
Good news: car runs very well - not a money pit.
Bad news: less exciting DIY Works!
Let's go back step-by-step - chronological order:
1. Oil change after 6K miles; in/out: TOTAL Quartz 9000 Energy, 5W40 + MAHLE O/F @ 239K miles
zoli_m13
BEFORE (pretty well cleaning off the paint by high pressure washer - located at passenger side, close to the headlight)
AFTER - installation a nice one from the scrap yard
- 19 Replies
- 3204 Views
Last post by befarrer
- 11 Replies
- 2934 Views
- 2446 Views
Last post by rdl1996
- 1909 Views
Last post by jlh3rd
- 2906 Views
Last post by packetfire
