1997 850 2.4 NA changed fuel pump yesterday. Car started rough but smoothed out immediately. Drove it around the block ran like a champ. Daughter tried driving it today, starts rough again. Too rough for her to try driving it. (I'm not home at the moment)
Any thoughts?
Rough running after fuel pump replacement
Craigd2599
- Year and Model: 2007 S40.
- Has thanked: 3 times
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
- Been thanked: 4069 times
You need to sort out if its on the ignition or fuel side of the troubleshooting tree.
Fuel pressure at rail is the solid test for delivery - usually nothing goes wrong after that.
How old are coil, cap rotor, wires, plugs?
Craigd2599
It's time for a tune up but the thing ran like a Singer sewing machine before the pump failed
Craig D
tryingbe
- Year and Model: None
- Been thanked: 26 times
Here's the thing; everything works until they don't.
So, instead of insist something worked great... verify what works and what doesn't. People on the internet can't troubleshoot a nd diagnosis without information, you can get the information by measure the fuel pressure at the fuel rail, do compression test, check spark plug wires, spark plugs, check compression numbers, and etc. If you can't do the work or don't want to, send it to a shop.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
Craigd2599
So...
I've worked on more than my share of Volvos, Chief. I went through the checklist when I diagnosed the fuel pump in the first place, which is why I'm asking here.
Maybe you haven't posted in a while, but this place is normally very friendly.
People here are helpful...not smug.
Thanks anyway
Thanks anyway
Craig D
Craigd2599
As soon as I got home and started the car, it ran perfectly. I'm thinking it had some air in the lines after the pump changeout. Ran it about five miles and it was flawless.abscate wrote: 25 Jul 2018, 14:39 You need to sort out if its on the ignition or fuel side of the troubleshooting tree.
Thanks for your input!
Craig D
I had quite a bit of cranking and sputtering on my 99 after the PCV job, where I had broken the fuel line and lost pressure. I suspect you are right on that diagnosis.
Craigd2599
Thank you! I'm driving it to work tomorrow (It's actually my daughter's car now) if it starts rough in the morning, I'll throw the pressure gauge back on it and see if it's leaking down. In which case I'll swap out the regulator. But I think we're okay.
Thanks again for your input!
Craig D
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
You haven't mentioned the brand of fuel pump you installed. If it's a Walbro, and you can't figure out what's causing the roughness, try pulling the pump, removing the filter and reinstalling it just to try it. The Walbro I bought wouldn't start my 850 at all. Finally discovered the sock filter that shipped with it was for E85 fuel and for some reason I still don't understand, it wouldn't pass through enough gasoline to start the car. With the filter removed it started and ran fine. The vendor finally sorted it out and sent me the right filter.
The wrong one has a rectangular pattern of small holes, maybe 1 mm diameter. The right one is a fine mesh with no distinctive holes. They're visibly different.
Craigd2599
This one had the fine mesh. I matched it with the old one before installing. It was an Airtex.
Craig D
- 1364 Views
Last post by Gymbo
- 16 Replies
- 2780 Views
Last post by Cookeh
- 1004 Views
Last post by oragex
- 1242 Views
Last post by Chuck W
- 42 Replies
- 12148 Views
Last post by Maestrours
