I have a Battery Tender battery charger.
Only used it in the garage while battery was in the 850.
Is it safe to remove the battery and charge inside my apt? Something tells me “NO”.
I’ll be home while it’s charging.
I don’t live in the same place, and no access to an outlet outdoors.
Thanks!
Safe to Charge Battery Indoors?
- loosenut
- Year and Model: 2006 V70R
- Been thanked: 7 times
Yes. It is safe...only do not open the caps on top that expose the water and plates...set it on 2 amp setting and it will take a few hours..if you are going to be around then ok go to 40 amp setting give it 40 mins...
NOTE....most batteries have caps... Check water OUTSIDE!!!!! fisrt!!!!!!!!.......top with bottled water or tap....it really doesn't matter....don't go buying battery water rip off....just to top up...fill to first sign of concave appearances....then charge away....
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Curious, this Interstate car battery I have doesn’t require water to be added.
In fact, I haven’t checked water levels in a battery since the 1970s when one used a mini turkey baster looking device which had different colored balls that would float.
My charger has only one “speed”. It works great but concerned about indoors, ie safe or not.
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Don't charge it in the appartment...toxic fumes will escape through the vent valve.
Put it outside...on the balcony.
Discharged battery will take around 12-15 hours to full charge at 4A.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
viper69
Thanks - had a feeling that would be bad idea.
Volvo 850 GLT 1995
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
The battery only releases hydrogen which isn't dangerous. flammable but you'd need to keep it in a box for that to be an issue.
And using a smart charger, which everyone should be by now, discussions about charge currents aren't really relevant apart from deciding how big a charger to buy.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hello,
I have charged my various lead acid batteries indoors and never had a problem. I make sure there is some ventilation.
Also, dont charge with too high of a current. For a regular car battery, probably 10 amps max is a safe level.
Of course make sure the charger does not try to over charge the battery either.
Also of course dont let the battery get shorted out, or else it could explode.
Also, no open flame or excessive heat near the battery.
The danger isnt really what might happen when you do everything right, the danger lies in what happens when you accidentally do something wrong. Batteries can explode so be careful, but with that care they usually dont explode.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
The engine bay of a car is a much more dangerous environment than an apartment and yet batteries thrive in that enviornment. There's no danger to charging a battery indoors.
- Been thanked: 4069 times
Do not attempt to cut hedges with your battery.
Do not drink battery acid.
Do not hold above your head and drop on your head.
I think I have covered everything else.
- Has thanked: 316 times
- Been thanked: 531 times
I wouldn't worry too much. If anything, just keep it by an open window. My cousin has charged batteries inside multiple times. I usually charge them in my garage, and that's somewhat inside. Still an enclosed space when the door is closed.
A smart charger is a good thing to have. I picked up a Viking 4 amp microprocessor controlled charger from Harbor Freight for $23 a while back. I've used it plenty of times and it works great to charge and maintain. You can change the settings for regular lead acid batteries or AGM, 6 or 12 volt. Plus it shows the voltage on the LCD.
- 9 Replies
- 9398 Views
Last post by Rattnalle
- 3904 Views
Last post by 240bri
- 4403 Views
Last post by jgibbs2273
- 811 Views
Last post by axisdj
- 1103 Views
Last post by cloaked45
