Safe to Charge Battery Indoors?
Has thanked: 1611 times
Been thanked: 4075 times
Hydrogen dissipates really quickly by dashing off into atmosphere and then heading out to space where it becomes stars, it will blow up, but the only thing left in the universe by then will be random P0455 codes floating in space
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Seriously though. A battery that had been properly flat won't ever be reliable again as a starter so just get a new one straight away.
And check the car to figure out why it went flat. Unless you just had the car sitting for a few months in which case it's quite normal for it to be drained
viper69
Year and Model: 850GLT 1995
Has thanked: 77 times
Post by viper69 »
Yep I’ve charged a different battery years ago and it did take a few years
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Rattnalle wrote: 11 Aug 2018, 01:22 Seriously though. A battery that had been properly flat won't ever be reliable again as a starter so just get a new one straight away.
I have brought starter batteries back from deep dead. It does take more time then most people can be without a battery.
Active
Past
Rattnalle
Post by Rattnalle »
RickHaleParker wrote: 11 Aug 2018, 01:50
They will never be anywhere near as good as new. They aren't designed to discharge more than a few percent. So it's a question of how much you value reliability vs cost.
RickHaleParker
Rattnalle wrote: 11 Aug 2018, 02:46 They will never be anywhere near as good as new. They aren't designed to discharge more than a few percent. So it's a question of how much you value reliability vs cost.
As long as the recovered battery is starting the car reliability, is as good as new. One of my recovered batteries is in my S90. It is reliable.
Active
Past
Rattnalle
Post by Rattnalle »
RickHaleParker wrote: 11 Aug 2018, 16:13
Good that it works for you. I still wouldn't risk it and I wouldn't recommend anyone else to do so. The batteries take damage from deep discharge. If that turns out to be an issue depends on what it's used for I guess. I'm not risking standing in the middle of the forest in winter with a flat battery.
viper69
Post by viper69 »
I'm done with figuring it out, trying to see if it will work or not. Time is too precious. I called AAA they replaced it for free.
Thank you all for your input however.
Volvo 850 GLT 1995
