Need to remove the driver's side door panel on my 1994 850 wagon.
driver's window is off the track, tilts when going up.
It will start raining later today, report says several days of rain.
so ASAP.
Howto remove door panel? window off track
- RickHaleParker
- Been thanked: 981 times
Active
Past
Past
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
Found this pictorial:
viewtopic.php?p=40467#40467
Still looking for how to get past the next layer to fix the window. Appears that the metal panel has a lot of stuff attached to the window on the other side, so don't want to remove more fasteners than necessary.
NEVER OPEN THE HOOD !!!
850forum
Found the OEM parts list, still dunno how to take it apart to see what's wrong
https://www.volvopartswebstore.com/show ... egory=7854
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- RickHaleParker
See the attached file.
1994_850_Replacing window mechanism slide.pdf- (238.3 KiB) Downloaded 411 times
Active
Past
Past
850forum
Finally got the download...
So I should not have to remove the whole window mechanism...
Replacing slide
Remove lift mechanism arm covers
-- hmmm, pieces of rubbery sheet, glued on ???
The rear hole is only about an inch diameter circle. No room to do anything thru that !
Or do I have to remove that much larger hard plastic piece, seems to be clipped on?
On pg 2, there are two arrow "B" items. To what are they pointing (different places !) , and why? Text does not say.
850forum
to remove a plastic snap-fit piece in the upper rear area of the "inner" door. Have to start at the top left & wiggle rightwards & up -- the lower right has a clip on the front surface that you don't want to break.
This is also the access point to fix the "roller" when it breaks or slides off of track fixed to the bottom of the window.
https://www.fcpeuro.com
P/N 9187646 Volvo Window Regulator Rail Front Left (850 S70 V70) Genuine Volvo 9187646
https://www.volvopartswebstore.com/cars ... parts.html
Home > Volvo > 850 > Body and interior > Window lift mechanism
SLIDING BLOCK P/N 3512837-0 (actually its a disk).
cotter pin is CLIP P/N 6817147
My Sliding Block broke the edges of the holes where the Clip goes thru. So the clip won't stay on if it flexes. I guess the new part number fixes that issue.
DIAGRAM & INSTRUCTIONS
download/file.php?id=41344
If the side window has come out of
line or fallen down the rear slide
may have cracked or broken.
Replace the rear slide in the front
doors and rear doors with the
improved version, P/N 3512837-0
according to instructions in this
Service Bulletin.
They designed this poorly. Its impossible to (esp in that tiny access panel):
1) push the "pin" on the scissors arm forcefully away from you, into the new Sliding Block. Someone needs to hold the door for you.
2) push the Clip into place -- its a heavy clip, needs to be compressed with pliers (don't drop it down the door !!! - tie a string to it !!!). Don't let it slide along the pliers as you push, but also don't compress it too much...
3) while at the same time preventing the Sliding Block from moving against being pushed on.
You cannot start the Clip partially in the Block.
They SHOULD have made the pin on the scissors arm a bolt-on component. Then you could put the Clip & Block & pin together, slide it onto the slide, and then line a hole on the scissors arm with the pin & tighten it down. In fact, the pin could have been press-fit onto the BLock as a roller, with a clip on the near side of the scissors arm. Or a bolt with toothed washer.
Service Bulletin.
850forum
The window guide (track) is held on by one bolt near the bottom.
How is the top end fitted ? Inserted into an upper track? Fiddly ?
Does it slip upwards putting the window into the groove? Window fully up?
- 781 Views
Last post by Vovo_merz
- 2750 Views
Last post by 686 Sport
- 741 Views
Last post by RickHaleParker
- 342 Views
- 2009 Views
