Cam cover removal
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Re: Cam cover removal
Post by prwood »
prwood wrote: 07 Sep 2018, 10:28
Cupojoe710 wrote: 07 Sep 2018, 10:21 I was expecting a lot more than just o rings lol. I appreciate all the help! As soon as my cam cover gets here I'll update on the process.
You might also want to replace the camshaft oil seals since they're going to come out anyway. In my case I had done that recently as a separate job, so they were in pretty good shape when I went to reseal the cam cover, and I just kept the same ones.
Also the VVT solenoid gasket(s) depending on the state of your solenoid(s).
Cars I've owned:
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Corteco
Has thanked: 292 times
Been thanked: 765 times
Nice job on the cam seals!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Cupojoe710
Year and Model: 2002 S60
Post by Cupojoe710 »
I forgot to mention I am also replacing my timing belt. Should I replace any pulleys or the tentioner while I'm at it?
BlackBart
Post by BlackBart »
Yep. New idler pulley and tensioner. These are the pieces that usually fail first. How old is your water pump? Easy to get to while you're in there.
Cupojoe710
My water pump is good, no squeaking or play. I have a question about the procedure. Why do I need a cam lock? To my knowledge it's just for keeping the cam in time, but if I'm redoing the timing do I need it?
prwood
Post by prwood »
Cupojoe710 wrote: 13 Sep 2018, 08:06 My water pump is good, no squeaking or play. I have a question about the procedure. Why do I need a cam lock? To my knowledge it's just for keeping the cam in time, but if I'm redoing the timing do I need it?
If you're redoing the timing, you need it to ensure that the cams don't turn out of time while the belt is off and cause valve damage. Especially when you're working the big VVT hub bolts on or off.
Cars I've owned:
Cupojoe710
That makes sense, would I need the cam lock for the rear of the cams or the front of the cams?
prwood
Post by prwood »
Cupojoe710 wrote: 13 Sep 2018, 08:30 That makes sense, would I need the cam lock for the rear of the cams or the front of the cams?
The cam lock tool I used goes on the rear of the cams:
https://www.fcpeuro.com/products/volvo- ... s-cta-2864
Cars I've owned:
prwood
Post by prwood »
And as BlackBart mentioned, do NOT crank down the bolts on the cam lock. I had the same issue as he did with a bolt getting stuck in the cam. Since then, whenever I have used the cam lock, I just finger tighten the bolts as much as I can - literally, just with my fingers. As long as you get it to the point where there is no in-out play, it will do its job.
Cars I've owned:
