Ive found someone in need of the rearmost seat and wanted to know if anyone has done the swap for a standard V70 rear 'trunk' floor.
It looks like its:
Seat bottom - just lifts out. I assume the non-seat bottom is same size
Seat Back - looks like rear trim needs to be removed to free seat
Seat belt latches - bolted to frame - maybe new bolts and sealer
Seat belt hip anchors - bolt accessible
Seat belt tethers- disappear into trim between C pillar and rear - ugh.
1999 V70 Third Seat Swap
- Has thanked: 1506 times
- Been thanked: 3819 times
Hardware all looks to be 16mm Hex (M10 size?)
What I have not yet figured out is how to get the seat back out - the forward part that pivots up to form the rear facing seat.
..and for the Pedantic - is it really the third rear set, the third, rear seat, or the second rear seat?
- Has thanked: 1851 times
- Been thanked: 1712 times
I thought I posted a how to on this, but if I didn't I'm sure there was one done a few years ago for possibly an 850 wagon by one of our regulars. V70 is the same. If you are still stuck, I will check on my return to Calgary if I still have that info on my pc for you.
Merci buckets, Neil
- Has thanked: 293 times
- Been thanked: 765 times
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
erikv11 wrote: ↑11 Sep 2018, 21:12 It's the cold seat.
viewtopic.php?t=49056 and yes, it explains how to remove the latch guide.
Thanks Erik
I’ll document the electrical disconnect when I do mine
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Speaking of third seats, there is a seemingly complete set up in one of the P80 V70s at Harry's in Hazelton in a medium tan. It looked to be in very good condition.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Thanks for bumping this ES, need to pull the one from CLARKE the 1998 this week.
