1999 S70 NA Hard Starting after fill-up
kumulipo
Year and Model: 1999 S70
Has thanked: 7 times
Post by kumulipo »
My 1999 s70 n/a has a hard time starting after a fillup, either automatically by the pump, or manually before the tank is full.
Tank is NOT topped off.
Engine will start but must maintain revs 3000+ to run.
Once underway, no problems.
Your thoughts, please.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
You are getting raw fuel into intake through carcoal canister.
It could be because of tank ventilation system failure.
If it does that always it would be fuel pressure regulator leaking fuel through vacuum line.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Any codes that are coming up?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 1504 times
Been thanked: 3817 times
No FPR on a 1999 with ME7 - but the overloaded EVAP canister is almost certainly it.
It moved to the rear passenger floor area, just in front of tire, in late 1998
Added year model to title per forum rules
misha
Post by misha »
abscate wrote: 02 Oct 2018, 06:29 No FPR on a 1999 with ME7 ...
Not even integrated in fuel pump housing/assembly?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
YEs, fuel pressure is regulated there, but without a vacuum line. It is electronically regulated by feedback from the fuel pressure sensor. I dont think that will cause the symptoms reported here.
misha
Post by misha »
P2 models have the same set up too...at least early ones...2000-2002.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha wrote: 02 Oct 2018, 07:29 P2 models have the same set up too...at least early ones...2000-2002.
I think it is
1992-1998 P80 Vacuum operated FPR - some on fuel rail, some on power steering rack (years/models?)
199-2001 Bastard FPR electronically regulated, fuel pump relay in fusebox, fuel pressure sensor ?
2002-2008 relay on CEM, CEM drives PEM with a signal, PEM drives fuel pump with another signal - fuel pressure measured on rail
kumulipo
Post by kumulipo »
Thanks for all your help.
Will post codes next time it happens.
I'm remembering P0405. That's not reliable.
So my repair would be the carbon cannister plus associated hosing? Plus checking the fuel rail situation?
Between fillups it starts easily.
Thanks again!
misha
Post by misha »
You must find the reason why carbon canister is flooding...not replacing it.
Doing that you will not solve nothing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
