Mystery hose leaking? in 940 AC system
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Katc
Year and Model: 1994 Volvo 940
Post by Katc »
Hello,
Learning more about my 940, but a novice.
The picture attached shows a hose between two aluminum (?) tubes at the front of the engine room. It looks like the hose is wet. As I can see, one end is connected to the AC compressor and the other goes to the radiator.
I'm guessing it's a leak. But I don't know what to call this hose to look for replacements (assuming it needs replacing). Any advice?
Front of engine room
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Is that the hose that goes back to compressor? If so, then it is the compressor discharge hose. It does like it leaks. You will likely have to get that one repaired. Some NAPA stores do hoses or could tell you who does. They repair them two ways. SOmetimes they can cut the crimp-clamp sleeve and take off old hose and replace hose and use new crimp sleeves. SOmetimes they cut the metal line and weld a barbed fitting on and replace hose section.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
jimmy57 wrote: 14 Oct 2018, 10:52 Some NAPA stores do hoses or could tell you who does.
OP claims to be from Bangkok
Have you seen a lift like this?
jimmy57
Post by jimmy57 »
I didn't look. New Asian Parts Affiliates? Need Auto Parts Anurak?
I've seen lifts like that. One of the choices in the Volvo Personal Service setup. If you search about car lifts there are some new arrangements. I was in a shop where they had portable twin post lifts. That looked scary to me.
