jack stowage - how does it work?
850forum
- Year and Model: 1995 850 turbo wagon
- Been thanked: 6 times
Re: jack stowage - how does it work?
A full size rim is $150 and I don't trust a refurb to stay inflated.
NEVER OPEN THE HOOD !!!
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Go to the junkyard and grab a steel spare rim with a tyre for cheap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 293 times
- Been thanked: 765 times
What's a refurb?
Also consider that alloy rims are also cheap at the junkyard and much lighter than steel ones. Easier to stow. Get one with a reasonably new tire on it. Inflate it to 40 psi and put it in the spare tire well. In 2 years when you think to check it again, it will be at something like 25-30 psi. And some 30x safer than a donut spare every day of those 2 years.
I've got some spare Cetus wheels with decent tires mounted, too bad I am local to just about no one on this forum ...
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
850forum
I have not been able to find a steel wheel with the correct bolt pattern online. I don't go to junkyards.
I have a lot of trouble with slow leaks -- I even bought 4 new rims some years ago, and one of them leaks
Reminds me, I should pump it up this morning, its been several days...
MY SPOKE PATTERN:
#14 Aluminum alloy wheel
6.5x16" TURBO 5 screw holes dark silver EXC T-5R 9134402 9134402 Aluminum alloy wheel
MY SPOKE PATTERN:
- misha
5x108 ET 35-49 6-6.5J CB 65.1
All big Volvos use the same bolt pattern.
Newer ones too but have higher ET...and as long as you stay up to ET 49 it is ok....ET 50 and higher will not fit.
That said....p2 models can use all p80 rims but p80 can't use p2 rims in some cases.
http://www.wheelfitment.eu/car/Volvo.html
Maybe the tires are too old(DOT#) and can't hold the pressure,valves are not sealing to the rim properly or rims are bent and leaking pressure.
I didn't seen the good rim leaking pressure YET.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 1506 times
- Been thanked: 3822 times
Your installer can put sealer on the rim. Tires should hold air for a long time, like months. I don’t have to add air in between seasonal adjustments every six months, if I do I haul it off and take it to my tire guy for a while you wait.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Unless the rim is bent/misformed, there is no reason it should be leaking that badly. Take it back and make the shop fix it / find a new tire shop.
What junkyards are you going to? Every junkyard I've ever been to either doesn't sell rims/tires, and I've never seen a yard sell alloy rims for less than $100 if you can find any there. However, I can get a set of 4 steel rims for $40 at the local salvage yard.erikv11 wrote: ↑17 Oct 2018, 18:10 Also consider that alloy rims are also cheap at the junkyard and much lighter than steel ones. Easier to stow. Get one with a reasonably new tire on it. Inflate it to 40 psi and put it in the spare tire well. In 2 years when you think to check it again, it will be at something like 25-30 psi. And some 30x safer than a donut spare every day of those 2 years.
Knows enough to be dangerous
That's funny, it never occurred to ma some yards wouldn't sell them, and I've never seen steel wheels that cheap. But I don't go to a lot of different yards - interesting to hear your experience. When I say cheap I am considering that you don't pay much more for an alloy than a steel, and the number OP threw out there ($150) for a spare.WhatAmIDoing wrote: ↑18 Oct 2018, 09:04 ...What junkyards are you going to? Every junkyard I've ever been to either doesn't sell rims/tires, and I've never seen a yard sell alloy rims for less than $100 if you can find any there. However, I can get a set of 4 steel rims for $40 at the local salvage yard.erikv11 wrote: ↑17 Oct 2018, 18:10 Also consider that alloy rims are also cheap at the junkyard and much lighter than steel ones. Easier to stow. Get one with a reasonably new tire on it. Inflate it to 40 psi and put it in the spare tire well. In 2 years when you think to check it again, it will be at something like 25-30 psi. And some 30x safer than a donut spare every day of those 2 years.
$21 for steel wheel with tire, $36 for alloy with tire (Or $21 if you can swap them a bent alloy as core ...), and I always see Volvos with alloy wheels when roaming this regionally popular yard: https://www.upullrparts.com/part-pricin ... c94c9-0c8e.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
$21 for steel wheel with tire, $36 for alloy with tire (Or $21 if you can swap them a bent alloy as core ...), and I always see Volvos with alloy wheels when roaming this regionally popular yard, they have a couple locations: https://www.upullrparts.com/part-pricin ... c94c9-0c8e.
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
