I just bought this car....85k. This is my 5th Volvo wagon...I guess I'm hooked! It is a beautiful car, BUT, really strong gas smell.
It seems to be worse after it has been parked for a while. I see no puddles of leaking gas.
I am a widow and really need some advice before I take it to a mechanic.
Strong Gasoline Odor Inside Car V70 2.4T 2002
- SuperHerman
- Been thanked: 207 times
Most likely the fuel pump. The top cracks and causes what you describe. Some have gotten by with applying a layer of JB Weld over the fuel pump plastic to cover the crack. Others just replace the part. Do a search for replacing the fuel pump and you will find what you need. Then remove the seats and get to the covers and examine the pump and confirm that is your issue.
- June
- Has thanked: 523 times
- Been thanked: 261 times
I had that happen in to my 2004 S80 and Volvo had a recall and fixed it for free March 16, 2016. It would be worth checking. Junemspanache wrote: 31 Oct 2018, 18:40 SuperHerman....thank you SO much for the speedy reply. This has driven me nuts, thinking I bought a lemon.
I will feel more confident talking to a mechanic. Thank you again!
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Been thanked: 4063 times
Have a good look under the fuel rail for dampness and fuel leaks. You don’t want any fuel leak anywhere,but especially near the hot engine. I’ll put up,a picture where to look.
- Year and Model: Lots
- Been thanked: 128 times
If someone has recently replaced the fuel pump and hasn't bothered to fit a new o ring to the top of the hold down ring you will get fuel odours. The o ring stretches when old and should be replaced upon re-installation of a new pump.
The smell would happen with a tank that's more than half full.
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
I had a strong gas smell with my '06 S60. It turned out to be that the fuel line at the gas filter had rusted and was leaking. The filter is just in front of the passenger rear wheel on the under side of the car. It is bigger than a soft drink can. Picture in the link. While my leak was outside, I could certainly smell it in the car. Also, at first there were no leaks seen on the ground.
You could scoot down there and check to see if the smell was stronger to check for a leak in that area.
Change your fuel filter how to
- 13 Replies
- 2357 Views
Last post by 93Regina
- 983 Views
Last post by cn90
- 2446 Views
Last post by mountain73
- 926 Views
Last post by JRL
- 9 Replies
- 1665 Views
