So, I just got back from L.A. visiting my son. His 2001 XC70 is on it's last legs...tranny issues, loss of power and someone backed into his rear passenger door. I would love to put him back into another Volvo, but I have no idea how to manage that long distance. He has about $10K and contemplated a lease of a Civic, Subaru or Mazda. Having always had Volvos (544, 140, P1800, 240, 740, S40, S60 and XC70) I am sold it the safety and solidity of the car. Having now driven on the expressways in LA, I really do want him in a safe vehicle. What would you all do it this situation? He is not 'a car guy', thus does not enjoy nor understand the pre-owned car buying process. He found a mechanic, but its a small independent shop run by Two Swedes (that's the name). They seem to only work on the older models, no resource for purchasing.
Had to put it out there, as I know he will call soon to tell me that his car has ended its life. !
Need purchasing advice
- Has thanked: 1614 times
- Been thanked: 4078 times
You can get a solid P2 for about 1/2 that budget, if you budget 6+2 for return timing belt and PCV you should do well
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It really is all about finding a car that really had good maintenance. As mentioned, if it had done the PCV, shocks, control arms with Sachs or Lemforder parts, it may meant it was well taken care of. But remember, a Volvo needs attention after 100000 miles and sometimes it can throw weird electrical issues that are hard to diagnose.
Comparatively, a 2018 CX-5/3 or a Honda HR-V (on the small side) or a Toyota CH-R (quite an interesting car) are quite more modern and safer cars, and especially trouble free in a lease. Sometimes the trips to the garage also need to come into the equation.
Ringo
- Year and Model: 2006 70XC
- Has thanked: 33 times
Hi Abscate - I'm facing a similar purchase. What's the RETURN? timing belt?abscate wrote: 07 Nov 2018, 18:33 You can get a solid P2 for about 1/2 that budget, if you budget 6+2 for return timing belt and PCV you should do well
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
Spell check fail
Refurbished timing belt and PCV
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
We love our 2004 Volvo XC70, it has 225k on the odometer and running strong. We originally purchased her 5-6 years ago for $4500 w/125k (I believe) on odometer. When we purchased her she had the Timing Belt Service with Water pump, tensioner and idle pulley replaced also. All 4 struts were replaced with factory Sachs, the ATF services were completed as recommended by manufacturer schedule. We recently purchased another Volvo, a 2004 XC90 T6 with 130k on the odometer. The Dealership had extensive records, the original owner (only 1owner) had followed all of the recommended preventive services as per manufacturer. The original owner had everything completed at Ramsey Volvo. I have a stack of records and a vehicle history report. This is what I look for when purchasing a new used vehicle. Almost every seller claims the Tbelt service was completed, I want proof!! After 100k the front end is usually getting bad, so look for repairs up there.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- Has thanked: 312 times
- Been thanked: 818 times
An 80k 04-07 Volvo goes for a lot more than $6k in LA, unfortunately. Maybe $8.5k. If you can find it sure, but in all probability you can't find it so ...
As stated by others I'm leaning toward the later model Honda or Toyota, without some DIY or the right mechanic. Either that or start looking now for the Volvo, a well maintained one for a cheap price in LA is pretty uncommon and bought up quickly, it probably won't be available they day the other car dies.
- 10 Replies
- 2337 Views
Last post by draser
- 2492 Views
Last post by F250
- 549 Views
Last post by a73s
- 2563 Views
Last post by June
- 1183 Views
Last post by precopster
